Author Topic: Door Hinge Rebuild  (Read 1524 times)
Offline MrMopar440
Door Hinge Rebuild
« on: June 12, 2008 - 06:01:46 AM »
OK, I finally got the sound deadner installed on my doors and most of the weatherstipping put on. I also rebuilt the window mechanisms and put up a plastic water shield. Now I need to tackle the door hinges since I can see and hear the lower one pop and move (wish I would have done it BEFORE the paint  :stomp: but needs done neverless). So I ran a search and was referred to the LA Mopar page. But is is now parked and MIA.  :'( Does anyone have the pictures and description saved? I figure it can't be that hard, but I would rather look at ones that have already been done before I go pulling mine off and screw them up. Thanks
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: Door Hinge Rebuild
« Reply #1 on: June 14, 2008 - 11:01:37 PM »
do the doors drop or sag when opened? if not you do not need to rebuild the hinges just need to soak the rollers. If they do. I have pin kits in stock for this reason. pins kits come with the bushings also. here is a link.
http://www.rosevillemoparts.com/advanced_search_result.php?keywords=hinge+pin&search_in_description=1&imageField.x=13&imageField.y=6
hope this helps
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline MrMopar440
« Reply #2 on: June 17, 2008 - 04:44:31 AM »
Thanks. Actually I already got a quote from you over at Roseville for the parts. I was just wondering how hard it was to do and if anyone had any tips or pics. Thanks
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #3 on: June 17, 2008 - 07:45:23 AM »
it is not hard at all. takes about 10 to 15 mintues per hinge to drill out and re-pin
Mopar Dave
73 F8 Challenger
1990 XJ - sold
Offline MrMopar440
« Reply #4 on: June 17, 2008 - 10:30:50 AM »
Thanks. Guess it will be like most of my undertakings with my baby - try it  :misbehaving: and see and hope for the best. Hopefully I will have my list together this week so I can get my order put in.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #5 on: June 17, 2008 - 10:49:54 AM »
when you got to that point of doing the hinges. mount them to the body so you have them bolted to a firm point for drilling for the bushings. You will have to grind off a little material on the lower hinge door side part to accept the space difference of the top of the bushing. Don't need to remove a lot/ just enough.
Mopar Dave
73 F8 Challenger
1990 XJ - sold
