Author Topic: Master cylinder... need some help  (Read 1197 times)
Offline JasonTx
« on: June 12, 2008 - 11:33:18 AM »
I have a 1970 cuda that has drum brakes. And i need to change the master cylinder. What is a good one to go with that works good?  I need some good stoping power. I got a big 440 in it.
 :dunno:
Thanks
« Last Edit: June 12, 2008 - 07:04:08 PM by JasonTx »
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Master cylinder... need some help
« Reply #1 on: June 13, 2008 - 02:46:47 PM »
A different master cylinder isnt going to give you more stopping power.
Offline ntstlgl1970
  • T a c o c a t
« Reply #2 on: June 13, 2008 - 03:28:04 PM »
:iagree: with Ted, as long as you have 4 wheel drum brakes, your car is never going to stop that well no matter what you do. As long as you are sticking with the drum master cylinder any decent name brand should be fine. Raybestos, Bendix etc.
Offline JasonTx
« Reply #3 on: June 13, 2008 - 07:29:13 PM »
If i put it back to disc on the front can i do it with out changing hte vacuum on the car?
Offline Katfish
  • 70 Challenger
« Reply #4 on: June 13, 2008 - 07:39:24 PM »
Sure, you don't need power disc brakes.  Just use manual discs, works fine for me.
Here's some great reading
http://www.moparaction.com/tech/archive/disc-main.html
« Reply #5 on: June 13, 2008 - 08:12:30 PM »
I got manual front discs on mine. It was an option in 1970
Offline JH27N0B
« Reply #6 on: June 14, 2008 - 12:20:39 AM »
All disc brake '70 E bodies were power.  Manual wasn't an option until '71.
« Reply #7 on: June 14, 2008 - 04:05:50 AM »
the 74 Dart had manual disc brakes & is an easy master cylinder to get rebuilt for a manual disc drum conversion
« Reply #8 on: June 14, 2008 - 08:03:30 AM »
Hmmm, when we looked it up at Car Quest, It showed 2 for 1970 disc brakes, 1 part number for power disc and the other for manual discs. Either way, it does work, it is on my car now and no problems
Offline JasonTx
« Reply #9 on: June 15, 2008 - 11:48:43 PM »
K thanks alot guys.!
