Hello, I have read all the posts you have written about the amps and cap. I have built many systems and only once did I need a cap for the amp. If you beef the altenator and your wire gauge you can get away with a strong system without a cap. I have also found through trial and error that you get what you pay for. Deals are great but sometimes you get burned. If the amp don't have a birth certificate stating true watts I never trust what is written on it. That is unless it is from big audio players(Kicker,MTX,Memphis,Rockford). With those companies the amps are usually under-rated.
In my opinion,,,,one sub,6x9's, two little amps,etc does not need a cap. Just get a good install kit and you're golden. I would craigslist all of that, take the money and get big name gear all the same(speakers amp,etc). Sony has good starter systems. I run all Memphis in my Durango, Kicker in my Jeep YJ and will have Memphis in my 65' Barracuda. I'll post pics of that build in the future.
