Author Topic: Mopar mini starter connections  (Read 1559 times)
Offline arcticmopar
  • Yukon Canada
« on: June 13, 2008 - 01:27:22 PM »
Hello,anybody else had problems with the main battery cable post on mini starters hitting the block? I have a Mopar perf piece and even after removing the terminal adapter I still had to cut down the stud as shorts as posible and it JUST clears the block. Will have to try and cover it to prevent a spark. Is it just me? :clueless:
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Re: Mopar mini starter connections
« Reply #1 on: June 13, 2008 - 06:23:29 PM »
I'll go out on a limb and guess you have a big block?
 I had to remove the adapter, but I was lucky my cable fit after that. It is a CLOSE fit though.(440)
Offline arcticmopar
  • Yukon Canada
« Reply #2 on: June 13, 2008 - 09:33:19 PM »
oops :dupe: ya its a 383. In my little mind I was sure I said that  :banghead: I have a boot that covers the terminals on an ATV winch that should help,was just wondering if anybody else saw it as a problem. Thanks again MEK. :thumbsup:
« Reply #3 on: June 13, 2008 - 09:38:47 PM »
Here's a tip....1000's installed monthly and very few incidents if any :2thumbs:  383/400/440/426    I run em on my race engines, but my m46 car has a regular starter and no issues
Offline arcticmopar
  • Yukon Canada
« Reply #4 on: June 14, 2008 - 01:40:04 PM »
Thanks Al, I swaped out the original starter because it was such a pain to shove into place with the TTI'S. Now I have to find another of those small nuts holding the wire from the relay. I droped it and its in there somewere but cant find it yet! :banghead:
