Author Topic: advise on changing gaskets  (Read 477 times)
Offline CrazyPete
« on: June 13, 2008 - 06:23:59 PM »
Im in need of changing my timing chain and oil pan gasket on my T/A any advise or tips before i dive in and do it?  I havent torn into a small block mopar in ALOT of years.  Thanks in advance
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Offline ntstlgl1970
  • T a c o c a t
Re: advise on changing gaskets
« Reply #1 on: June 13, 2008 - 06:45:11 PM »
if you can, after draining the radiator, pull the drain plugs from the sides of the block to reduce the amount of coolant that ends up in the oil pan after pulling the timing cover/water pump. Also change the timing cover seal and if needed, put a speedi sleeve on the crank dampner if it has a groove worn in it.
