Author Topic: Dana 60 e-body ??????  (Read 1530 times)
Tower Rat 95B
« on: June 14, 2008 - 06:34:58 AM »
 70 Challenger with Dana 60 are there #'s some where on the axle that can match it to the car?  In other words my tranny has the cars vin# stamped on it , does the Dana also have the vin somewhere?   Ive been chipping paint but find nothing so far..........
nivvy
Re: Dana 60 e-body ??????
« Reply #1 on: June 14, 2008 - 06:48:37 AM »
All Dana 60 housings are marked with a "Bill of Materials" number and a date code (Figure 2). BoM numbers are found on the back of the right axle tube, 2-3 inches outboard of the center section. All Dana 60 differentials are also marked with a date code. The 'font' for these stampings is a sans serif style and the characters are about 1/8" high. Particularly for the axle tubes, the stampings are faint, so it is important to clean the area well and to visualize them in good light. The BoM number is a 6-digit number with a one or two digit suffix separated by a dash: XXXXXX- X. Date codes are found on both housing and differential and are formatted MM DD Y. Date codes are found inboard of the BoM number on the housing, and on the side of the cylindrical part of the differential. The year code on housings is always one digit and on differentials can be two digits. Housing date codes are followed by a letter (A, B, or C) which may indicate the work shift or factory line. Some differential stampings also show this letter suffix. Zeros are not used in month and day codes. Wide variation in spacing of the components of the date code is seen, and it is not unheard of to see two date codes stamped into a housing, one above the other. These two date codes are usually within a few weeks of one another.
Bill of Materials Numbers:
68-69      B body      3.54       Powr-Lok         602957-1, -2, -3, -4
                       4.10       Powr-Lok         602957-5, -6
69.5-72    B body      3.54       Powr-Lok         603109-1, -2
                       4.10       Powr-Lok         603109-3, -5
                       4.56       Powr-Lok         603109-6, -7, -8
70-72      B body      3.54       Trac-Lok         603222-1, -2
                       4.10       Trac-Lok         603222-3
                       4.56       Trac-Lok         603222-4
75-77      B body      5.13       Powr-Lok         603347-2
                       5.38       Powr-Lok         603347-1
69-71      E body      3.54       Powr-Lok         603080-1, -2, -4
                       4.10       Powr-Lok         603080-3, -5
                       4.56       Powr-Lok         603080-6, -7
70-72      E body      3.54       Trac-Lok         603226-1, -2
                       4.10       Trac-Lok         603226-4
74         E body      5.38       Powr-Lok         603425-1
77-78      Retail      4.10       Trac-Lok         603831-1
           Maint.
67-70      D200/W200   Std                         602423
68.5-70    D200/W200   Std, Powr-Lok               602010
69.5-72    D200/W200   Std, Powr-Lok, Trac-Lok     603016
71.5-75    D200/W200   Std, Trac-Lok               603236
76         D200/W200   Std, Trac-Lok               603769
77         D200/W200   Std, Trac-Lok               603775
78         D200/W200   Std, Trac-Lok               603892
71-75      D200/W200HD  Std, Trac-Lok              603237
76-78      D200/W200HD  Std, Trac-Lok              603647
70-71      B300/M300   Std, Powr-Lok, Trac-Lok     603160
71.5-74    B300/M300   Std, Trac-Lok               603313
74.5-75    B300/M300   Std, Trac-Lok               603516
76         B300/M300   Std, Trac-Lok               603645
76.5       B300/M300   Std, Trac-Lok               603768
77-78      B300/M300   Std, Trac-Lok               603774
78         B300 Maxi   Std                         603832
Tower Rat 95B
« Reply #2 on: June 15, 2008 - 08:36:50 AM »
 Ok thanks  :bigsmile: :bigsmile:,,,,,,,so if my car is fender coded for a 4.10 track pack the bom# should read out as a trac-lok or powr-lok ?        I will have to do some more scrapping for the bom #'s and post will post them later............
                                 Thanks...........
