Author Topic: Intake ????  (Read 799 times)
Offline Pentastar Pete
Intake ????
« on: June 16, 2008 - 05:31:12 PM »
I having a 360 built for my 74 Challenger.. I'm in the market for an intake..   :bananasmi
The car is going to be street driven, and every now and then a run down the track.
Whats the difference in performance between a single and dual plane????
and what the benefit to a high-rise, with the rallye hood I def. have the clearance....
Thanks Peter :wavingflag:
Does anyone have an opinion on the Summit stage 3 intakes?????
« Last Edit: June 16, 2008 - 05:59:23 PM by Pentastar Pete »
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
Offline 422STROKER
  • Member Since 6/3/06
Re: Intake ????
« Reply #1 on: June 16, 2008 - 06:24:43 PM »
Hey Pete, the summit intakes are good for the $$, but not as nice as the Air-gaps.  But will work nicely or your 360.  If $$$ is the issue then the Stage 3 if not Air-Gap. :2cents:
Tom
By tdavist, shot with DSC-P72 at 2008-05-25
By tdavist, shot with DSC-P72 at 2008-04-26
Tom
Re: Intake ????
« Reply #2 on: June 16, 2008 - 06:31:59 PM »
Tom, is that the summit stage 3 with the raised plenum???
68 Charger RT
Offline 422STROKER
Re: Intake ????
« Reply #3 on: June 16, 2008 - 07:19:35 PM »
Yes, I'm running it on my SB stroker and only have 1 complaint, cold start-ups are slow with the heatless intake.
Tom
By tdavist, shot with DSC-P72 at 2008-04-14
Tom
Offline moper
Re: Intake ????
« Reply #4 on: June 17, 2008 - 12:07:48 PM »
Tom.... There are more than one....lol Just not from you   :bigsmile:
I don't think I'll use another one.  :smilielol:
They have casting issues, possible sealing issues, hole finishing issues, sensor fitting (mechanical gage) issues... But they are alumium, and they do work once the issues are addressed. But $ for $ in terms of a builder, go for the Edelbrock.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Intake ????
« Reply #5 on: June 17, 2008 - 01:44:25 PM »
I went with the RPM non-Airgap, so that I could have great midrange and not have the engine take a longtime to warm up during a cold start.
A dual plane is mainly for low and midrange rpm power.
A single plane is mainly for midrange and high rpm power.
Since you plan to mainly have a street motor I would go with the dual plane, but to give you a good choice, we need to hear what you plan to use in the motor; i.e. compression, heads, cam, carb, etc.
Offline 422STROKER
Re: Intake ????
« Reply #6 on: June 17, 2008 - 07:55:35 PM »
That's why you make the big $$$. :smilielol:
I just drive it and report back. :2thumbs:
Tom
Yes I would probably spend the extra dough if i did it again.  But I think it is good for the $$$.
Tom
