Author Topic: luggage rack  (Read 3179 times)
Offline roy282
luggage rack
« on: June 16, 2008 - 06:58:36 PM »
Was hoping someone would be able to answers a few questions for me about the luggage rack on the 70 gran coupe barracuda? 1 were the rear deck lids a one year only thing to accommodate the luggage rack? and 2 were the racks on convertibles the same as hard tops? and 3 how do you know the different between e bodies and other makes and models? last could someone post some pictures of the underside of the rear deck lid to give me a rough ideal to where it was placed? or the exact measurements would be greatly appreciated!! Thanks Rob
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Alaskan_TA
Re: luggage rack
« Reply #1 on: June 16, 2008 - 09:26:12 PM »
If you have the right decklid, some (maybe all, I do not remember for sure) of the mounting holes are pre-punched in the underskin.
Re: luggage rack
« Reply #2 on: June 16, 2008 - 09:39:33 PM »
I was also going to say that every decklid I have come across has had the holes underneath in the bottom frame showing the location, just needing to be drilled out. Just like hoodpin holes only go in 1 place.
Offline roy282
Re: luggage rack
« Reply #3 on: June 16, 2008 - 09:51:47 PM »
Thanks Alaskan_TA for your reply and Moparal here are a few pics
« Last Edit: June 16, 2008 - 10:22:34 PM by roy282 »
Offline Challenger6pak
Re: luggage rack
« Reply #4 on: June 16, 2008 - 09:55:43 PM »
The factory drilled the holes in the trunk lid and then put inserts in the lid so the lugage rack could be screwed to the trunk lid. These inserts look like the ones that were used on the doors to hold the mirrors except that they were larger. The 1970 and 1971 deck lids have openings cut on the backside where the luggage rack attaches.
Offline roy282
Re: luggage rack
« Reply #5 on: June 16, 2008 - 10:20:00 PM »
Thanks Challenger6pak here's a close up of what I have. Rob
Re: luggage rack
« Reply #6 on: June 16, 2008 - 10:47:48 PM »
You have the 72 up lid. You can use it if you don't care about originality on the back side of the lid. You can drill the holes and use nuts behind the screws to hold the rack on.
To answer some of your other questions the rack is the same on hardtops, convertibles, 71 and 72 B-bodies and early 70's Corvettes. I believe 70-72 Vetts. GM and Chrysler bought them from the same supplier.
All 70 & 71 deck lids were made to accept the luggage rack option.
Offline roy282
Re: luggage rack
« Reply #7 on: June 17, 2008 - 04:44:25 PM »
Thanks for the info and your time Challenger6pak could you tell me or show me a picture of what the 70/71 rear deck lid looked like so that I may know what to look for. Thanks again Rob
Offline FY1 RT SE
Re: luggage rack
« Reply #8 on: June 17, 2008 - 06:40:18 PM »
IIRC corvette racks are different.
Offline hemiken
Re: luggage rack
« Reply #9 on: June 17, 2008 - 08:19:25 PM »
Here are some picture of my brothers trunk lid on his 71 Gran coupe, sorry about the picture quality or lack of it, used my phone for the pictures.
Offline roy282
Re: luggage rack
« Reply #10 on: June 17, 2008 - 10:39:45 PM »
Great visual Thanks  hemiken you're a great help!! Would you  know if the 4 flat washers that rest under the rack/on top of the lid are supposed to be chrome or polished stainless? And last I'm still not sure on what the difference is between the 70/71 trunk lid to the other years? Thought mine was a 70?? Thanks Rob
Alaskan_TA
Re: luggage rack
« Reply #11 on: June 17, 2008 - 11:41:32 PM »
The washers under the rivet nuts were the tooth lock variety, so I would guess that they were zinc coated, but I do not know that for sure.
If I remember right, the earlier 1970 cars had a deck lid that only had the provisions for the luggage rack.
Then, once the rear spoiler became an option, another decklid was added to the mix.
Once the T/As came into prduction with the ducktail spoiler, they had a deck lid with provisions for all three options.
Every 1971 deck lid I have seen is the same so far, has  provisions for all three.
It changed again for 72, not sure after that...............
Hopefully someone here has photos of all the 1970 types?  :dunno:
Offline 71ChallengerSE
Re: luggage rack
« Reply #12 on: June 17, 2008 - 11:54:52 PM »
there were I think 4 different decklids for the challenger and cuda
1 without spoiler holes
1 with go-wing holes
1 with t/a spoiler holes
1 with the go-wing and t/a spoiler holes
Alaskan_TA
Re: luggage rack
« Reply #13 on: June 18, 2008 - 12:20:08 AM »
In that image, the bottom left shows Challenger with luggage rack holes.
The bottom right shows provisions for the luggage rack and both spoilers.
So, at least one is missing geneologically speaking.........  :1zhelp:
Re: luggage rack
« Reply #14 on: June 18, 2008 - 12:33:13 AM »
My new decklid only has the holes for the luggage rack, but my old original 71 decklid had all the holes for everything so I think Barry is right about all 71 decklids having all the holes.
