Author Topic: Engine Balancing  (Read 1127 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Engine Balancing
« on: June 17, 2008 - 01:36:21 AM »
I just want to make sure I am correct about this:
When dealing with all big blocks (both B and RB), if you have a forged crank it will be internally ballanced and if you have a cast crank it will be externally balanced.  Is this correct?
Thanks
Re: Engine Balancing
« Reply #1 on: June 17, 2008 - 02:28:46 AM »
basically yes , most  cast cranks are externally ballanced , except the 383 2 bbl in 69 - 70
most steel cranks are internally balanced except the 70 -71 HP / 6 Pack  engines with the heavy rods
Offline NoMope Greg
« Reply #2 on: June 17, 2008 - 02:36:30 AM »
Ummm...teachable moment here - CP, can you please tell me the difference between external and internal balance?  Internal is with mallory metal and/or milling the counterweights and external is on the flywheel?   :clueless:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #3 on: June 17, 2008 - 03:20:53 AM »
internal means there is enough weight on the crank counterweights to balance the the piston & rod weight , external means the damper & flywheel or torque converter have weight added to balance it
Offline Jacksboys
« Reply #4 on: June 17, 2008 - 01:23:50 PM »
Thanks Chryco   :2thumbs:
Is it easy to spot the 70 -71 HP / 6 Pack  engines?  I mean if they are not in a car.
Thanks
« Last Edit: June 17, 2008 - 01:28:18 PM by jacksboys »
Offline Finoke
« Reply #5 on: June 17, 2008 - 01:25:55 PM »
Well said  :2thumbs:
« Reply #6 on: June 18, 2008 - 03:29:57 AM »
the damper is offset on the HP engines , it is not difficult to spot when looking for it
Offline Jacksboys
« Reply #7 on: June 18, 2008 - 10:22:06 AM »
Ok thanks   :2thumbs:
