Any Aluminum Radiator you guys recomend?
Author Topic: Any Aluminum Radiator you guys recomend?  (Read 12821 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: June 17, 2008 - 01:55:52 PM »
I'm looking for an aluminum radiator to replace my stock 26" 4 core radiator. As it does not flow well anymore. And I'm thinking of getting  electric fan(s) as well. As the old mecanical clutch fan just doesn't do the job if I get stuck in trafic. Almost over heated to many times. Do you guys have any aluminum radiator to recomed? Bolt in kit with electric fan would be the best, right?
My car is a 70 'cuda 383 A/C car (A/C removed) with A/T
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
nivvy
Re: Any Aluminum Radiator you guys recomend?
« Reply #1 on: June 17, 2008 - 01:59:25 PM »
Be Cool  :bigsmile: ............. Less exspensive Griffin.........  each one is only good to so much HP ...........  :2thumbs:
Offline widing'cuda
nivvy
« Reply #3 on: June 17, 2008 - 02:18:27 PM »
 didnt see aything about HP rating.......... seems shady for the price.......... My $1100 be cool setup is good to 400HP and 700HP total with the electric fans.......  :working:
Offline widing'cuda
« Reply #4 on: June 17, 2008 - 02:37:45 PM »
Offline widing'cuda
« Reply #5 on: June 17, 2008 - 02:46:40 PM »
Do you have a link to any Be Cool Radiator kit that don't need to reloacte the battery. Bolts stock in. 500 HP should be fine
nivvy
« Reply #6 on: June 17, 2008 - 02:50:49 PM »
minewas a bolt in witout moving the batt.... i put it in the trunk anyway.... te 1000HP kit you need to relo with.....
nivvy
« Reply #7 on: June 17, 2008 - 02:53:18 PM »
Same radiator: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=010&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=200230236302&rd=1
Quate: "It Will Cool your car up to.....750hp....."Guaranteed."
Yea for how long.... lol  ..... Just seems to good for the price.... If they cool 750HP for $220 the would have there own business like be cool and put be cool out of business.......  :2cents: think about it............ 750HP on the radiator alone.......
http://www.becool.com
« Last Edit: June 17, 2008 - 02:57:32 PM by StRoKer »
Offline widing'cuda
« Reply #8 on: June 17, 2008 - 03:10:42 PM »
True. I found this one http://store.summitracing.com/partdetail.asp?part=BCI%2D82016
It goes to 400 HP acording to http://www.becool.com/
Why is the rate of the horse power that importen? As I only have a cooling issue when the 'cuda standing still or in a trafic jam/ que
nivvy
« Reply #9 on: June 17, 2008 - 03:15:06 PM »
simple.... I would run hot all day with a 400hp application.... standing still in the traffic is the worst of all.... no wind cooling.....  :working:
thats stuff is written up so shady....
We have a littly tiny baby radiator thats cools down the 900HP aluminum Indy block.... only makes 1/4 miles passes though  :eek7:
Offline widing'cuda
« Reply #10 on: June 17, 2008 - 03:43:28 PM »
So I need like a 1000HP radiator then? My 'cuda a 383 with about 350 HP more or less.
like this: http://store.summitracing.com/partdetail.asp?part=BCI%2D82176
But then I need to put the battery in the trunk.
Or will it work fin with the http://store.summitracing.com/partdetail.asp?part=BCI%2D82016
nivvy
« Reply #11 on: June 17, 2008 - 05:04:50 PM »
1000 is way overklil fo your app.... I believe they make a 400 hp one....
Offline widing'cuda
« Reply #12 on: June 17, 2008 - 05:55:00 PM »
Ok, This one is up to 400 HP: http://store.summitracing.com/partdetail.asp?part=BCI%2D82016
nivvy
« Reply #13 on: June 17, 2008 - 06:47:37 PM »
I had room with the 700HP kit and didnt have to put battery in trunk.... just did for weight transfer.....  :working:
FYI - I have never ran hot .... track or street......
Offline BB73Challenger
« Reply #14 on: June 17, 2008 - 08:16:55 PM »
I hated overheating problems, they plagued me like I was cursed!!
The one thing I learned was moving the air is very important.
There are different "grades" of rads to buy, but my cheapy universal rad is made into a cooling stud by putting serious fan power behind it.
I could cool well enough on the streets and great on the freeway, but stopped at a light and give me the Thanksgiving Day turkey for frying.  :hyper:
The nice thing about the one you seem to be pondering is it seems like it's welded at all the seems. My "cheapy" is epoxied and I read they will not last forever.
Jeff from Cleveland, Ohio
