Any Aluminum Radiator you guys recomend?
Author Topic: Any Aluminum Radiator you guys recomend?  (Read 12827 times)
Offline cudagirl4406pk
    • Garageartmusclecars
Re: Any Aluminum Radiator you guys recomend?
« Reply #30 on: June 19, 2008 - 07:29:27 AM »
Well i use the becool radiator setup with electric fans the setup is about 1200.00 i know that is expensive but it works terriffic.
michele
Offline IMNCARN82
  • LeDZeP
« Reply #31 on: June 19, 2008 - 01:21:48 PM »
I tried a jegs alum.200.00 radiator.Need to go with a BC to fit with the alterKation.700.00!! :banghead: The Jegs twin 12" fans for 189.00 are awsome!They move more than enough air for my 340. :dunno:    More than the factory IMO.
« Last Edit: June 19, 2008 - 01:24:27 PM by IMNCARN82 »
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #32 on: July 06, 2008 - 05:31:40 PM »
Anyone tried Flex-a-lite 26" core Radiator with electric fan kit? Looks real nice. But is it hard to install, or is it bolt on?
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline Changin Gears
« Reply #33 on: July 06, 2008 - 07:12:53 PM »
Don't know anything about it, but from the picture the cap is below the top of the radiator.  Doesn't seem possible to fill it up, the top 2 or 3 rows would only have air in them.
Offline Carlwalski
« Reply #34 on: July 06, 2008 - 07:44:45 PM »
I'm running a 26" Griffin on my 540ci Hemi, Tim Banning recommended and purchased mine on my behalf and shipped it over with my crates. I'll be painting it black so I'll loose a little cooling but from what Tim the builder said heat won't be an issue with this engine. Alloy engine helps too, dissipates heat faster. Can't comment on them but if Tim says it's good, it 's good. ;D
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline matt63
« Reply #35 on: July 06, 2008 - 07:49:05 PM »
I'm running the 22" Flexalite with my 408.  It has a fantastic mounting system as you can adjust the rad up and down by allowing the t-bolts to slide up and down in the slots.
Matt in Edmonton
'68 Valiant
Offline widing'cuda
« Reply #36 on: July 07, 2008 - 03:00:18 PM »
Got any part No. for the rad? And does it fit withot modes? What fan shroud have you got for it. Electric fan?
Offline widing'cuda
« Reply #37 on: July 07, 2008 - 03:01:10 PM »
Cool. Do you have any picture of you setup? Was it hard to install?
Offline jvike
  • Pro-Touring Cuda
« Reply #38 on: July 07, 2008 - 04:08:28 PM »
I'm running a 22" Griffin universial radiator with a swiched electric fan on my 340. Heat is not a problem anymore, I only use the fan when cruising in town on very hot days and if I leave it ideling.
Offline widing'cuda
« Reply #39 on: July 07, 2008 - 04:14:02 PM »
Got a picture of you setup? I need a 26" one as my 'cuda has a 26" radiator in it now.
Offline jvike
  • Pro-Touring Cuda
« Reply #40 on: July 07, 2008 - 06:32:42 PM »
I Couldn't find any pics of the mounts, but there were non on the radiator, had to fab them myself.. Can take a picture of it if you want..
Offline Got JOB
  • Member since 2-14-06
« Reply #41 on: July 07, 2008 - 06:43:53 PM »
I'm using a BeCool with the stock fan. Fit good but had to improvise to fit the stock shroud.
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline widing'cuda
« Reply #42 on: July 08, 2008 - 01:42:42 PM »
So there are noe brackets on the radiator to mount it the the radiator suport? I picture would be nice, thanks
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #43 on: July 08, 2008 - 02:56:03 PM »
Check Fred out I think he has what you are looking for direct bolt in and custom also. I used his stuff and so have some others  :2thumbs:
http://www.cuda-challenger.com/cc/index.php?topic=42056.msg476935#msg476935
I BUILD ALUMINUM RADIATORS FOR MOPARS. EBODYS ARE MY SPECIALITY. I OFFER YOU A 26IN. HEMI/440 RADIATOR.THESE RADIATORS ARE BUILT USING A SPECIAL MADE CORE. THESE CORES ARE MADE WITH 2-(1.25 IN .)TUBES. HEADERS ARE 3.13. MOST ALUMINUM RADS ARE 2- (1 IN.TUBES) IN A AVERAGE 26 IN. CORE, YOU WILL INCREASE YOUR FLOW AND VOLUME BY 30%. I WILL BUILD TO SUIT YOUR NEEDS ,IF YOU NEED SOMETHING SPECIAL.I OFFER YOU A HAND FABRICATED TANK,AND FULLY HAND TIGGED RAD THAT PREFORMS AND HAS BEEN PROVEN ON THE STREET AND THE STRIP. THE WELDS ARE SHOW QUALITY. I ALSO OFFER A HAND FABRICATED AND HAND STAMPED LOOK, THAT MATCHES THE ORIGINAL AS CLOSE AS POSSIBLE. I HAVE EVEN HAD A FEW BLACK ANODIZED, FOR THAT REAL ORIGINAL LOOK. 22INCH RADIATORS ARE ALSO AVAILABLE. I MAY NEED TO GET SOME OVERALL MEASURMENTS YOU GUYS MY FELLOWMOPAR FRIENDS.ALL RADS HAVE SHROUD ISERTS,OR FLANGES WILL BE PROVIDED. THE COST IS $525 MANUAL/$575 AUTOMATICS FOR HAND FAB LOOK, AND $550 MANUAL/$600 AUTOMATICS FOR THE STAMPED LOOK .ALL RADIATORS ARE GARANTEED.. SHIPPING WILL BE FROM MID MI. AND WILL BE INSURED. S&H WILL BE$35. OTHER PRODUCTS ARE AVAILABLE SUCH AS OVERFLOW CANS, ETC... HOPE YOU HAVE A COOL SUMMER ,,,YOU CAN EMAIL ME DIRECT,,,FRICO@CHARTER.NET
Go Fast & Have Fun...
Offline 71chally416
    • The Streetwalker
« Reply #44 on: July 08, 2008 - 03:43:32 PM »
Another option if you want it to drop in, bolt up and look stock.
http://chucker54.stores.yahoo.net/mucaralra1.html
