Any Aluminum Radiator you guys recomend?
Author Topic: Any Aluminum Radiator you guys recomend?  (Read 12823 times)
Offline moparmaniac59
  • Drive it like ya stole it!
Re: Any Aluminum Radiator you guys recomend?
« Reply #45 on: July 08, 2008 - 05:10:29 PM »
I put a post in this section about Smith Racing Radiators. I had asked if anyone was familiar with them, but no response. I guess they are fairly new to the market. :dunno: Due to the cost of copper, it would have cost me 800 bucks to recore my factory radiator.  :scared:I couldn't see paying that much, so I ordered a direct fit big block 26" down flow aluminum radiator (4-core with 1 1/4" tubing) from Smith Radiators and it arrived today. I can say without a doubt that it is a good quality piece and fit very well (and looks good too). I had to do just a little adjustment for interference with my washer fluid reservoir bottle. The radiator has mounting brackets that match to the factory location and tabs for drilling/mounting a fan shroud (my factory fan shroud fit perfect). The company is in Cambridge City, Indiana. The radiator was about 600 bucks, but well worth it. It is fitted with a drain plug, transmisson cooler and as mentioned, mounting brackets. You can check out the site at www.smithsradiator.com. Good product. I recommend them!! :2thumbs: If there is any interest I can take a pic and post it of the installed radiator.  :2thumbs:
        Matt B.
Matt
« Reply #46 on: July 08, 2008 - 05:28:19 PM »
Hey Matt,
   I'll just check it out in person in 2 days!!    :jumping:
I'm glad it is working for you.   :2thumbs:
Offline matt63
« Reply #47 on: July 08, 2008 - 10:15:23 PM »
Cool. Do you have any picture of you setup? Was it hard to install?
Here is a couple of pics
Matt in Edmonton
'68 Valiant
Offline 71chally416
    • The Streetwalker
« Reply #48 on: July 08, 2008 - 10:19:49 PM »
That's cool as ****l!
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #49 on: July 10, 2008 - 03:55:13 PM »
Now that's nice  :bigsmile: Do you have 22" og 26" opening in the radiator suport? P/N 52180R Right?
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline matt63
« Reply #50 on: July 10, 2008 - 09:51:44 PM »
It's a 22 inch opening.  I think the p/n is correct as the 26 c/w 2-10" fans.  I would call Flexalite on a recommendation.  I doubt the 26" would fit without relocating the battery and some cutting.
Matt in Edmonton
'68 Valiant
Offline KellysCuda aircard
  • Its good to be blown
« Reply #51 on: July 11, 2008 - 10:59:16 AM »
Be Cool  :bigsmile: ............. Less exspensive Griffin.........  each one is only good to so much HP ...........  :2thumbs:
With out a doubt, hands down the only rad that is even a consideration. I used to over heat at an idle, I tried other aluminum rad packages and fan combos, but when the smoke cleared the only one that worked and come with a guaranteed to keep my car cool is BE COOL. It was pricey but well worth the cash, they are custom made for the E body and worth every penny. Dont be stingy with the cash when it comes down to keeping your cool.   :2thumbs:
Offline widing'cuda
« Reply #52 on: July 11, 2008 - 11:22:20 AM »
What's the p/n for the becool setup then?
Offline widing'cuda
« Reply #53 on: July 11, 2008 - 11:41:56 AM »
I have mersured up the 26" core rad and it will not fit. So I Guess I have to look at det 22" core rad insted. Much modes you had to do to install it?
Offline matt63
« Reply #54 on: July 11, 2008 - 12:21:34 PM »
Easy install.  You might need to find an upper rad hose that fits or go to a flex type hose.  I ended up increasing my alternator size to run the fan and keep 12v at idle which was a bit of a job.
Matt in Edmonton
'68 Valiant
Offline widing'cuda
« Reply #55 on: July 11, 2008 - 01:07:40 PM »
Ok, cool. I'm hoping the uper hose will fit as my has stock pas. side inlet as teh new rad has. But but that should be a problem anyway.
I have 92 amp Powermaster alternator allready and a large battery, so that shouldn't be a problem.
« Reply #56 on: July 11, 2008 - 02:13:14 PM »
Just phone them, they will set you up, they are great to talk to, and I believe they offer a money back guarantee. I bought the one for a challenger by mistake, they sent me the correct one in exchange and I didnt even buy it directly from them.
Offline matt63
« Reply #57 on: July 11, 2008 - 03:25:35 PM »
For a big block I might be tempted to pay the big bucks and get the BeCool.
Matt in Edmonton
'68 Valiant
Offline widing'cuda
« Reply #58 on: July 11, 2008 - 04:38:16 PM »
I see that one he becool application the terminal switch is to be installed in one of the heads and not in the radiator. Why?
Offline Ornamental
  • Oslo, Norway
« Reply #59 on: February 14, 2009 - 01:23:36 PM »
I tried a jegs alum.200.00 radiator.Need to go with a BC to fit with the alterKation.700.00!! :banghead: The Jegs twin 12" fans for 189.00 are awsome!They move more than enough air for my 340. :dunno:    More than the factory IMO.
What?!?!
NEED to go with a BC due to Alterktion?
Not that I don't believe you, I do, but why is it so?
The reason I'm asking is that there will be a Alterktion in my Challenger this year (Or else widing'cuda will slap me like a b!tch, and quite rightly so. I've had it lying around far too long now).
Which BC and fans did you end up with?
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
