Author Topic: Request Heads/Rocker advice for 440  (Read 798 times)
Offline 71chmark
« on: June 17, 2008 - 05:14:59 PM »
440 running bad.  Popped the valve covers off and my friend was able to compress several of the springs by hand.  Said that was bad.  He says the springs "forgot where they were supposed to be" after sitting in a semi compressed state for over 12 years.  Any ways, I figured I might as well upgrade.  I have the Purple cam, 750 DP Holley on a torquer intake, 1 3/4 headers and a standard bore and pistons.  The heads are stock 346 heads.  This is just a 4 speed street car.  I want to replace and/or upgrade the heads and valve train to maybe get a few more hp.   I'd like to limit cost to around a thousand, but I don't want to go too overboard.  You know the law of diminishing returns.  I have basically zero engine knowledge so would appriciate any advice.
I may be schizophrenic,
nivvy
Re: Request Heads/Rocker advice for 440
« Reply #1 on: June 17, 2008 - 05:29:12 PM »
Offline 71chmark
« Reply #2 on: June 17, 2008 - 05:37:18 PM »
Thanks.  I've emptied it.  I have seen your rockers.  Are they hard to set up?  What else would I need?
nivvy
« Reply #3 on: June 17, 2008 - 06:51:04 PM »
nothing else needed......ready o bolt on..... I forgot to mention they have alot of shims in them for rocker tip alignment... those dumb little shims are like 1.00 a piece  :eek2:
real easy........ I will even help you through it i needed.....  :2thumbs:
« Reply #4 on: June 18, 2008 - 03:33:04 AM »
Crane Ductile Iron rockers are relatively cheap & very reliable & available in both 1.5 & 1.6 ratios
 the Comp Promagnum rockers are about the best bang for the buck for a roller but are not available in 1.6 yet
Offline moper
« Reply #5 on: June 20, 2008 - 12:12:41 PM »
What purple cam?
Offline 71chmark
« Reply #6 on: June 20, 2008 - 12:15:18 PM »
.284/.484
