Author Topic: What about these heads?  (Read 1224 times)
Offline 6packCuda
Re: What about these heads?
« Reply #1 on: June 17, 2008 - 07:19:04 PM »
What are you planning on putting them on? The 915s, although more expensive, are probably the better choice because of the closed chamber design.
« Reply #2 on: June 17, 2008 - 07:20:30 PM »
The prices are REAL nice.  :grinyes:
I would feel better if they mentioned something about hardened valve seals, to deal with unleaded gas. Also, no mention of porting, so these would be stock heads, I assume.
« Reply #3 on: June 18, 2008 - 03:34:48 AM »
I prefer the closed chamber heads for the combustion charicteristics , depends what the rest of the combo is though , with a big stroker you amy nto want that much compression
Offline 71chmark
« Reply #4 on: June 18, 2008 - 06:55:47 AM »
Purple cam, 750 DP Holley on a torquer intake, 1 3/4 headers and a standard bore and pistons.  The heads I have now are stock 346 heads.  This is a 4 speed street car.  I want to replace and/or upgrade the heads and valve train to maybe get a few more hp.  I don't want to go too overboard.  You know the law of diminishing returns.  I have basically zero engine knowledge so would appriciate any advice.  I'm going with StRoKers roller rockers so do you think the 516s would be a good choice or maybe some built 906s?  Basically i'd like to get the best head for my combo and keep it under a thousand bucks.  If I ever go to a stroker I would upgrade the heads anyway.
I may be schizophrenic,
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #5 on: June 18, 2008 - 10:38:49 AM »
I agree with Chryco on the closed chamber design.
I would also make sure they have harden seats, or you will have to add a lead substitute everytime you put fuel in the tank. (a real pain on a long trip)
What type pistons do you have?  When at TDC, how far are they in the hole?
Offline 71chmark
« Reply #6 on: June 18, 2008 - 11:12:47 AM »
Stock flat top piston.  Stock block.  I'll measure when I get the old heads off.  How much room do you think I would need?  I remember there was some room.  Say I had the 516 or 915 closed chamber and the 1.7 Roller Rockers.  I just plan on using 93 octane pump gas.
« Reply #7 on: June 18, 2008 - 11:22:24 AM »
Agian it depends on the piston , anything over 525 lift could get into piston to valve clearance problems unless the pistons are ntoched , typically the closed chamber heads will increase compression by approx 1 point but usually you can get away with that as the factory compression was never as high as advertized
Offline Jacksboys
« Reply #8 on: June 18, 2008 - 11:25:47 AM »
nivvy
« Reply #9 on: June 18, 2008 - 04:26:04 PM »
he will be at .520 net lift........ x2 on the closed chamber heads though.......
Offline moper
« Reply #10 on: June 19, 2008 - 12:56:46 PM »
You get waht you pay for. The 516s look better. The 906s pictured have not been milled...
Offline 71chmark
« Reply #11 on: June 19, 2008 - 02:42:20 PM »
I like the 516 heads also.  Maybe I'll just get an assortment and try them all.  Where did I put that wallet anyway?
