Author Topic: Help Deciphering Fender Tag  (Read 11495 times)
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re:Help Deciphering Fender Tag
« Reply #30 on: March 20, 2004 - 10:26:46 PM »
JS...I see a 4 also...but the first letter I see as an S.  That's what threw me off when they started talking about a G.  It is soooo hard to tell.  I wish there was a specific place they put the codes...like most of the paint codes are on the 4th line first code.  I wish I knew what "usually" goes in the 2nd line first code.
Let me see if I have a pic of my mirrors anywhere...they're at the chrome shop right now.
« Last Edit: March 20, 2004 - 10:27:19 PM by Rev-It-Up »
Offline Carlwalski
« Reply #31 on: March 21, 2004 - 03:04:43 AM »
My final guess after looking at it for ages is this: G34 = Outside LH Remote Racing Mirror  8)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Pistol Gripper
« Reply #32 on: March 21, 2004 - 08:46:43 AM »
Rev,
Here's my complete fender tag for a 1974:
102
N76 R35 V5X 26 L2
J54 L31 M21 M26 N41 N42
EW1  U  B41 C56 G11  G54
EW1 A6X9 000 C05 239278
E58 D34 JH23 L4B 262526
I'm not sure there is real order to all the numbers, but maybe you can figure it out from a few examples.
P.G.
O ne
B ig
A $$
M istake
A merica
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #33 on: March 21, 2004 - 01:27:08 PM »
I'm still G35, hope we find out to see who is right and who was wrong, it's like a bet.  ;D
Does this mean I won the bet?? :P
2013 Tige' RZR 343hp
Offline Carlwalski
« Reply #34 on: March 21, 2004 - 06:59:55 PM »
I'd say so, but then again I was the first to put the hand up and take on the G3, first reply, so I was out in the open for a lashing.  ;D ;)
By the way, I didn't hear the call for betting ends?!? LOL!!  ;D
If you look under the line above the "4" you can see easily the top of the "5" shape. But I'm still not 100%, the only reason I'm going "4" is because the shape of the "5" is to close to the bottom of the other ones (the ones above).  :)
Good call though you were the first to guess correct.  ;)
« Last Edit: March 21, 2004 - 07:00:37 PM by NZ 440RT »
Offline JS27N0B
« Reply #35 on: March 21, 2004 - 09:46:39 PM »
The 26 inch rad was a no brainer as the car was coded for A/C and of course every fender tag has an END or EN1.
The more tags you see the easier it is to pick up on things. I always look at fender tags, see if the car is what it was when new and see if it had any cool options or combos.
Offline Transamcuda.com
  • Numbers cruncher and expert at nothing.
    • Transamcuda.com
« Reply #36 on: March 21, 2004 - 10:18:47 PM »
Rev you dont need to use Galen to get the tag made. Go to AG Backeast and he will make your tag for you and he wont charge you as much as Galen. Here is a link to his web site. http://www.datatags.com/ By the way this is the same place Galen uses to get tags made so you dont have to worry about them being correct cause they will be!!!!  ;D
Dont forget to register your AAR at the AAR Registry only at www.transamcuda.com 1981 AAR's on file. Also info on 70 thru 74 E-Bodies. Ask me about yours!!
Offline Rev-It-Up
  • Global Moderator
« Reply #37 on: March 21, 2004 - 10:39:57 PM »
Thanks for the infor TAC!!  I'll look into it for sure...anything to save a few bucks!
