Author Topic: Mechanical Valve Lash  (Read 2675 times)
Offline Camshaft
« on: June 18, 2008 - 11:28:28 AM »
I have a 340 with iron heads and a a mechanical valve train, and it's time to set the valve lash.  I don't have the exact cam specs as it was installed by the PO, but I do know that it is a Mopar Performance with a .490 lift.
Do the clearances change with different manufacturers... MP, Crane, Comp, etc?
I have spent a number of hours searching, but I didn't come up with much so any help is appreciated.
Thanks,
Cam
'74 Challenger R/T
'03 Ram 1500 QC Hemi
'06 Honda VFR 800
'06 Infiniti G35 coupe(wifes)
Re: Mechanical Valve Lash
« Reply #1 on: June 18, 2008 - 11:40:04 AM »
Mopar cams have different lash to most cams , typically they call for .028 intake & .032 exhaust , I generally set them .026 / .030
Offline Camshaft
« Reply #2 on: June 18, 2008 - 12:24:16 PM »
Thanks.  That's on a hot engine right?
'74 Challenger R/T
'06 Honda VFR 800
nivvy
« Reply #3 on: June 18, 2008 - 04:26:43 PM »
yes.......
Offline 71chmark
« Reply #4 on: June 18, 2008 - 05:04:56 PM »
Do you set the lash while the engine is running?  I have seen this done on an old 302 mustang some 30 years ago.  What do set for initially (cold)? The same and then readjust after hot?
I may be schizophrenic,
nivvy
« Reply #5 on: June 18, 2008 - 05:31:20 PM »
see my updated how to:    :2thumbs:
Offline Camshaft
« Reply #6 on: June 18, 2008 - 06:17:55 PM »
Another question... if your valve lash is way out, will it cause detonation?  I've been getting some serious pinging under load.  I went with a cooler plug and retarded the timing way back to 30*, and it cleaned up most of it, but it's still there.  The engine is supposed to be 10.7:1 compression ratio (built by PO)... kinda high for pump gas isn't it?
Thoughts?
'74 Challenger R/T
'06 Honda VFR 800
nivvy
« Reply #7 on: June 18, 2008 - 10:57:04 PM »
Thoughts?
10.71 with irons heads is a time bomb waiting to happen ...............  :aarg:
« Reply #8 on: June 19, 2008 - 03:00:25 AM »
yes lash can contribute to ping , slightly as it can change the cam proflie & increase cylinder filling with RPM , but really not significantly
 10.7 : 1 with most of the ping gone on pump fuel is awesome , it should be pinging with that compression
Offline Camshaft
« Reply #9 on: June 19, 2008 - 08:45:00 AM »
Okay, so it's an excuse to buy some new aluminum heads.  I'm sure that there are a ton of threads out there on the subject... what is the most popular?  Edelbrock?
I've got so many things to do to this car... I don't know where to start!  $$$
Do you think an octane booster would help in the mean time?
'74 Challenger R/T
'06 Honda VFR 800
« Reply #10 on: June 19, 2008 - 11:02:20 AM »
Octane booster will help , the Eddy heads will drop you to effectively 10:1 , personally I am not a fan of the eddy & would spend more to get a real head IMO :2cents:
