Driveshaft
Author Topic: Driveshaft  (Read 1290 times)
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
Driveshaft
« on: June 18, 2008 - 12:27:22 PM »
One of my Challenger has a bad Driveshaft, so will a Driveshaft from a 69 Charger fit or is it wrong length?
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Offline ESGEE
    • SG´s site
Re: Driveshaft
« Reply #1 on: June 18, 2008 - 06:35:46 PM »
Both are 383 Magnum/727/8 3/4
70 Charger 500
Re: Driveshaft
« Reply #2 on: June 18, 2008 - 06:53:17 PM »
I am sure the leaf springs are a different lenght, that given, I think the wheel base is different. I don't believe the shafts are the same lenght. But there are differences from rearend sizes that play a roll for drive shaft lenght. Like a dana e body has a shorter shaft as with b bodies. Not sure if an 8 1/4 rear would have a different lenght. The ebodies I believe were 46.50 or in that area. I do know you need to make sure the shaft has enough travel as to not bottom out into the trans.
Re: Driveshaft
« Reply #3 on: June 19, 2008 - 02:51:44 AM »
Charger has a longer wheel base , it will not fit
nivvy
Re: Driveshaft
« Reply #4 on: June 19, 2008 - 03:37:05 AM »
Wanna buy mine...................      :working: has spicer u joints also ....... send me a pm
Offline ESGEE
    • SG´s site
Re: Driveshaft
« Reply #5 on: June 19, 2008 - 09:27:53 AM »
Sent you an PM :cheers:
70 Charger 500
nivvy
Re: Driveshaft
« Reply #6 on: June 19, 2008 - 02:39:54 PM »
inbox is full.....
Offline ESGEE
    • SG´s site
Re: Driveshaft
« Reply #7 on: June 19, 2008 - 02:58:03 PM »
Mail me insted
« Last Edit: June 20, 2008 - 11:43:34 AM by ESGEE »
70 Charger 500
