Author Topic: My little 383 project - expert opinions please  (Read 2159 times)
Offline Born_Fast
  • RIGHT PEDAL :: LEFT LANE
Re: My little 383 project - expert opinions please
« Reply #15 on: June 21, 2008 - 07:05:25 AM »
the Avenger is a basic street carb with choke , easily tuned , the HP series & Proforms are more race carbs with no choke & even more tunability which is especialy good for enignes with low vacuum a bigger cams
So then i'll have to check the vacuum of my engine and if it's low, i'd better go for a HP or Proform?
If the gain in HP is about equal with all three carbs, i'd prefer an easy to tune Avenger.
« Reply #16 on: June 21, 2008 - 10:28:31 AM »
Makes sense , the Hp carbs will offer a bit more gain & generally these cars are not driven in cold weather so the choke is no real factor except for the first 2-3 minutes when you start it up cold
Offline Robb
« Reply #17 on: June 22, 2008 - 02:26:48 AM »
My rear tires are 255/60R15. Would be awesome if you can calculate my gear ratio from that!
I'm living partially in Germany, Switzerland and Austria.
so using a diameter of 27" for that size of tire  and 3500 rpm at 70 mph
Rear End Gear Ratio  4.017857142857143  ?
your speedo might be off ?  Might use a Neverlost (GPS) to get an actual vehicle speed as obviously the above number doesnt equate to an availble gear ratio.   Id guess you have 3.91s or 4.10's   but thats a guesstimate
Cool.  I am fortunate to be able to say that I have been there, been there and been there.   Beautiful places.
« Last Edit: June 22, 2008 - 03:05:01 PM by Robb »
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
