Author Topic: Lord, thanks for not taking me! 7/30/08 Update.... Back in business!  (Read 7754 times)
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Lord, Take me now!!!
« Reply #30 on: June 23, 2008 - 12:00:39 AM »
The one attached to the coil is for noise suppression.  If you had a points-style distributor the ignition condenser should be attached to the distributor if I remember correctly (I replaced the points unit on my '71 with the Direct Connection kit back in '81)
Aha!  Very cool, thanks duodec!  :thumbsup:
Sorry the car is still acting up, Wally.   :(
Offline wally426ci
    • maryland mopars
« Reply #31 on: June 23, 2008 - 07:42:29 AM »
Thanks Guys, anyone else checking this out (look @ page 2 for the latest symptoms)  :swear:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline IMNCARN82
  • LeDZeP
« Reply #32 on: June 23, 2008 - 09:30:29 AM »
could you post some pics of your engine?   Let us take a look.  :dunno:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline kingtroll
« Reply #33 on: June 23, 2008 - 10:31:19 AM »
 :popcorn:
1974 Barracuda
Offline wally426ci
    • maryland mopars
« Reply #34 on: June 23, 2008 - 10:58:52 AM »
Well, i can later this week. Im also getting from AbodiesOnly site that it could be the pick-up coil in the distributor?  :clueless:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline redfastback
    • my shop
« Reply #35 on: June 23, 2008 - 11:04:32 AM »
you did mention that you fixed wiring at the ballast resistor.  what all does that mean?  tell us how it is wired.
"barracudas are like the pitbulls of the ocean"
Offline BacardiCBR
« Reply #36 on: June 25, 2008 - 01:37:23 AM »
What carburetor is it?
Do you smell gas when it's experiencing the symptom?
Do you have a fuel filter before the fuel pump, after the fuel pump, or both?
If you let it cool down for a while, will it restart and run normally at idle?
I like all the suggestions from others:
- fuel filter
- fuel line route away from heat
- vacuum lines
- check plugs
- check grounds (a burnt ECU?  Eeck!)
- carb float levels
- clean carb (not sure if this has been mentioned yet - Also, don't forget that they sometimes have the little metal screen "filter" right inside there where the fuel line attaches to the carb)
'70 AAR Tribute Car
Offline wally426ci
    • maryland mopars
« Reply #37 on: June 25, 2008 - 07:01:58 AM »
Well, since i "messed" with electical, it may be electrically related?  :thinkerg:
can anyone give any input on the pickup coil in the distributor?  :feedback:
Oh, and theres a new fuel filter before the fuel pump. havent cleaned carb for a while or checked plugs yet.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline hemiken
« Reply #38 on: June 25, 2008 - 08:01:38 AM »
Hey Wally,
What was the fuel filter you fitted buddy........................... :P
« Reply #39 on: June 25, 2008 - 09:45:02 AM »
Wally, a couple of thoughts.
  Have a jumper wire handy the next time its acting up & jump from + battery to input side of ballast resistor, see if problem goes away.
  Yes  the pickup coil can be bad breaking down with heat.
  Why are you running a filter before the pump? This could be creating a restriction. I was even thinking before I read about the filter that you might have a fuel supply hose, before the pump, collapsing when it got hot from pump suction. (a long shot but I have heard of it)
Wade
Offline wally426ci
    • maryland mopars
« Reply #40 on: June 25, 2008 - 12:47:13 PM »
I heard that in 71 the filter swent before the pump, up to 70 is after.......
thats the way its always been, so i wouldnt think it would be the filter. Im running a metal canister. 7/16 lines
I'll post a diagram i used later on........
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline CUDA JAS
  • vroooooom!
« Reply #41 on: June 25, 2008 - 01:05:17 PM »
Have you checked the plug wires, as was suggested earlier???
Good luck man.
74 'cuda 360/727
Just call me a gearhead!
Offline wally426ci
    • maryland mopars
« Reply #42 on: June 26, 2008 - 07:03:58 AM »
I'll get time this weekend. Thanks for all of the suggestions guys. will do!  :chatting:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline wally426ci
    • maryland mopars
Re: Lord, Take me now!!! 7/5/08 Update....
« Reply #43 on: July 05, 2008 - 01:16:48 PM »
So, i pulled the distirbutor last night (a new MP distributor a year ago) and noticed that the reluctor was a little ugly compared to what i beleive it should be; not to mention the air gap looks to be slightly larger than the recomended .008" gap.  this could explain why its always been hard to start, and the scarred up reluctor could explain the miss that i cant find. I picked up a new pick up coil, cap & rotor and i have another distributor that has a reluctor in good condition with nice square edges.
I have a document that Chrysler put out on tuning the ignition system that i found on MyMopar.com, i tried posting it but the file is too large.
 :chatting: I'll update everyone on what the outcome is this time.  :working:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline NoMope Greg
« Reply #44 on: July 05, 2008 - 03:38:25 PM »
Can you post the link to the document?
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
