Author Topic: What are those holes for?????????  (Read 1174 times)
Tower Rat 95B
« on: June 21, 2008 - 07:29:39 AM »
  Down on the fender wells toward the front there are squarish looking access type holes big enough to put your hand through, looks like maybe acccess to the calipers was the idea but I dunno is there a reason for those opennings???????????
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
Re: What are those holes for?????????
« Reply #1 on: June 21, 2008 - 07:41:35 AM »
It's so you can get to the cam bolts when you do an a alignments
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Tower Rat 95B
« Reply #2 on: June 21, 2008 - 03:41:29 PM »
 Chuck71,   Thanks always wonder what they were for,   I think at one time there was a peice of plastic covering them.........  thanks for the pic too :bigsmile:
« Reply #3 on: June 21, 2008 - 03:44:52 PM »
It will be a metal cover. And will also keep dirt and water from coming into the engine bay
Offline Katfish
  • 70 Challenger
« Reply #4 on: June 21, 2008 - 04:04:21 PM »
Mine are a soft material.  Almost like tar-paper
« Reply #5 on: June 21, 2008 - 04:39:19 PM »
The tar paper is for the lowest part of the fender well. Sell the yellow circle?  That should be steel with 2 screws
Offline Katfish
  • 70 Challenger
« Reply #6 on: June 21, 2008 - 07:54:03 PM »
I stand corrected, you are absolutely right.  Went outside and double checked.
Offline js27
  • MOPAR OR NO CAR
« Reply #7 on: June 23, 2008 - 11:42:54 AM »
The holes are for access to your caster-camber-adjustment.
JS27
1967 GTX
1970 Dodge Challenger R/T Conv.
Offline MDMoparDude
« Reply #8 on: July 07, 2008 - 05:43:32 PM »
They are reproducing the covers for them......
