Author Topic: Before or after  (Read 900 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Before or after
« on: June 21, 2008 - 02:27:48 PM »
Finally getting the Cuda on the street after plugging the emission holes on the new heads. Now the engine is getting warm after I shut it off
and also difficult to start when warm so I guess the timing is either late or early. Is "afterboiling" indicating late or early timing and wich direction
of turning the distributor changes late to early?  :feedback:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline GoodysGotaCuda
Re: Before or after
« Reply #1 on: June 21, 2008 - 04:07:18 PM »
Engine is supposed to get hot when you shut it down, there isn't a way i know of around that, except an electric water pump and fan setup that runs after the engine shuts down. Heat soak, take that coolant that was running at 180* being turned by the water pump...and stop it. All that heat from the block dramatically heats up the coolant that is now stuck in the block with no airflow, and no circulation. Your hard hot start may be due to vaporlock/fuel issues as well. But you definately need to get a timing light on it as well if you don't know where it is set.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Before or after
« Reply #2 on: June 21, 2008 - 10:10:35 PM »
Thanks! How many degrees at idle? With or without vacuum?  It's a -70 340, a liitle bit unstable at idle with the eddy rpm camshaft and
airgap intake. What's the timing with vacuumadvance and giving throttle?
Re: Before or after
« Reply #3 on: June 22, 2008 - 01:00:43 AM »
I would start with around 18* at idle & 36 at 2500 +  rpm . no vacuum advance
Offline hooD
  • detroit iron
  • Motor City Made Muscle
Re: Before or after
« Reply #4 on: June 22, 2008 - 01:18:55 AM »
Ignition timing might be the issue.....but your difficulty with warm starts may be related to your carburetor leaking fuel into the engine after shut down.  This would cause a "flood" condition which would cause the hard starts after the engine reaches its full operating tempertures.
« Last Edit: June 22, 2008 - 01:21:03 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Re: Before or after
« Reply #5 on: June 22, 2008 - 01:14:09 PM »
Well, I can adjust the distributor 1/8 of a turn without any difference in performance. Strange engine.  :clueless:
Re: Before or after
« Reply #6 on: June 23, 2008 - 03:02:25 AM »
some are like that so set it closer to the retarded end of the no change area
