1993 D250 3/4 ton 2wd Club cab LE with the 5.9 CUMMINS and automatic. Power windows, locks, mirrors, tilt, cruise, and cold A/C.
Kenwood CD/MP3 player with remote thats bluetooth/HD/and satellite radio ready.
Sony Xplode 6x9's in the doors, factory 4x7's in the back, and a 10" Pioneer sub in the back powered by a 300w Pyramid amp.
Has a brake controller, and cobra CB radio. A pillar and dash mounted Auto Meter Pro Comp Ultra Lite Gauges (Trans temp, Pyro "EGT", Boost, Water temp, and Oil pressure).
Has tread plate tool box, and bed caps. Bed rails, Brush guard, bug shield, step bars, and a plastic bed liner, but has two cut outs from a 5th wheel from the previous owner.
40/20/40 front seat from a 97 Dodge truck.
Things it needs..... Headliner has come loose and needs re-glued (I planned to replace). The arm rests have come loose at the front and need replaced.
Windshield has rock chips and one bad spot very top left drivers side.
Planned on replacing the Bad dodge designed steering box coupler with a borgenson steering shaft and u-joint.
The odometer (not the speedo) stopped working approximately 3-4000 miles ago. Probably less, but... The small gear it needs is 28 bucks. So it has right at 260,000 miles. Anyone that knows about these Cummins, knows that is nothing. It runs Great. Pulls hard, and I wouldn't be afraid to head across the country with it. Towing something or just by itself. I have got 22 Mpg out of it, but usually averages 19-20 Mpg. Only thing I've ever had to replace was a lift pump.
Minor body work and a Paint job would really make it turn some heads.
I've had several people stop me trying to get me to sell it in the past, but no way would I part with it. I really don't want to now, but I dont drive it much.
Asking $6750.00 or trade for A Barracuda of like value. I will consider a Challenger also. I know an E-bod in this range is usually a project, so I'm not gonna be unrealistic and greedy either.
I
might consider other mopars, just have to see. Truck is located in central Arkansas. Any questions, you can contact me here by PM or at
blkonblk72cuda@yahoo.com Thanks,
HSD
