Author Topic: rear end width  (Read 1043 times)
Offline tyler
rear end width
« on: June 21, 2008 - 05:50:15 PM »
does anyone know what the width of a stock rear end is?  i measured from the face of where the brakes would mont to.  the one i have is 61 3/8" wide,,,it seems pretty wide.  it is a strange engineering dana 60.
Offline ksierens
    • 70 Challenger Resurrection
Re: rear end width
« Reply #1 on: June 21, 2008 - 07:41:27 PM »
My stock Dana looks to be about 61 5/8"
Kurt - SE Michigan
Re: rear end width
« Reply #2 on: June 21, 2008 - 07:43:29 PM »
I thought backing plate to backing plate was around 56.5  and tracking was around 61. I will go check and see
Re: rear end width
« Reply #3 on: June 21, 2008 - 07:46:03 PM »
61 5/8ths is right
Re: rear end width
« Reply #4 on: June 21, 2008 - 07:48:58 PM »
Offline tyler
Re: rear end width
« Reply #5 on: June 22, 2008 - 01:50:44 PM »
what do you mean by flange?  after hearing 61 5/8" it is that rather than 3/8" like i had said.  Or where is the propper place to measure from for the width?  I really appreciate the help!
Re: rear end width
« Reply #6 on: June 22, 2008 - 05:55:18 PM »
61 5/8ths is from where the lugnuts are on both sides, or rather drum to drum. The flange is what the drum bolts to, which is 65.5    Did you follow the link?
Offline tyler
Re: rear end width
« Reply #7 on: June 22, 2008 - 07:01:27 PM »
ahh...i didnt see the diagram on the bottom of it.  thanks a lot!
