small block super commando heads and offset rockers
Author Topic: small block super commando heads and offset rockers  (Read 2324 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: June 22, 2008 - 11:23:43 AM »
Does anyone know if the aluminum heads that Mopar is running on the new 440 super commando stroker small block and offset rockers are available seperately? I heard they were called super commando heads but can't find a part number for them anywhere.
1996 Dodge Viper GTS Coupe
Offline 72hemi
Offline Ornamental
  • Oslo, Norway
Re: small block super commando heads and offset rockers
« Reply #2 on: June 23, 2008 - 04:59:22 PM »
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline 71chally416
    • The Streetwalker
« Reply #3 on: July 23, 2008 - 01:23:18 AM »
MP LARGE PORT COMMANDO FLOW #'s
AS CAST OUT OF BOX------PORTED
LIFT-----------IN/EX------------IN/EX
.100”------60.6/N/A----------74.3/NA
.200”-----103.7/92.8--------147.7/122.9
.300”-----153.4/131.0-------207.5/192.4
.400”-----200.6/152.8-------254/1/233.4
.450”-----223.3/156.9-------274.5/241.3
.500”-----240.2/162.4-------289.2/243.0
.550”-----252.2/164.6-------302.4/243.0
.600”-----245.2/165.9-------311.9/243.0
.650”-----245.2/166.5-------311.9/243.0
.700”-----245.2/166.5-------311.9/243.0
All #'s @ 28" H20
Offline go-fish
« Reply #4 on: July 23, 2008 - 07:16:09 AM »
You will have to use high dollar Harland Sharp or T&D rockers and pedestals. Those things make the price of the bare head, which is reasonable, go sky high. That would be a big money set of heads when you are done but they would be better than W-2's.
« Last Edit: July 23, 2008 - 07:37:23 AM by go-fish »
Offline 71chally416
    • The Streetwalker
« Reply #5 on: July 23, 2008 - 08:23:25 AM »
This is what I have on mine (Big port Commandos) B-1 BB Rockers. I had to move the CL of the hold down bolts. W-2 rocker gear bolts right on according to Ryan at ShadyDell. The heads themselves need work in the chambers because they are very small and shroud the valves, but with some work they are very nice. They can also support a big inch small block like mine (416) with porting, or will work great for a smaller motor with minor work. Mine peaked at 6,250 on the dyno. These heads are the same as the Aluminum Magnum R/T heads but have the Intake holes drilled for the old type manifolds.
« Last Edit: July 23, 2008 - 08:36:51 AM by 71chally416 »
