I figured this would be the best place for advice. I am looking for what Intake and carb i should get for my 74 360 motor. Also since im still 18 living with my rents i dont have a ton of money to spend on the top of the line gear. Im just looking for good performance thats not so hard on the wallet. If it helps you guys i just a week ago installed headers and 2.5 exhaust(shaved 1/2 a sec of my 1/8th mile time). Thanks alot guys!
Gear ratio dependent, the 750 could be to large for great street manors. A smaller 650 wouold fit the bill well if you have 3.55's or numerically lower gears. Even more so with 3.23's or 2.76's etc.......
With that said, if you want to change the intake and carb, spend for the RPM and figure out the carb as per my suggestion on gear ratio.
IF it were me, I'd look to a cam change. Then gear ratio. A street strip car with 4.10's perform well.
The only problem the T-Q should present is tuning the idle and cruise curcit's since rods are not at the corner store. Many seem to frown on bending a AFB rod 3/4 inch shorter to work with a T-Q. Why? I don't know. It works.
OH, also the AFB step up springs will work in the T-Q. There smaller, but will function fine.
