Author Topic: Spring pressure  (Read 580 times)
Offline 71chmark
Spring pressure
« on: June 22, 2008 - 05:25:23 PM »
Should I be able to put the palm of my hand on my stock valve springs while installed and in the car an compress the springs?  I only weigh about 150#.  I'm told this means my springs are too weak.
I may be schizophrenic,
moparniac
Re: Spring pressure
« Reply #1 on: June 22, 2008 - 07:39:38 PM »
crappy way to do a test.... just change the springs and be safe..... get 10* locks also...   :2cents:
« Last Edit: June 22, 2008 - 07:41:16 PM by pentastar »
Offline Changin Gears
Re: Spring pressure
« Reply #2 on: June 22, 2008 - 09:02:10 PM »
Seat pressure of a flat tappet cam is anywhere from 100 to 150lbs, so if you can push down that much force the valve will begin to open.  It isn't a good way to test, but it doesn't mean anything is wrong either.
Offline MrMopar440
Re: Spring pressure
« Reply #3 on: June 23, 2008 - 06:59:43 AM »
 :iagree: Definately test them with the right equipment before you go out a replacing parts unless doing so for a different reason.
Offline moper
Re: Spring pressure
« Reply #4 on: June 23, 2008 - 05:07:51 PM »
stock springs are weak. And the stock cams are small, so they match. Dont create a problem where none exist...lol
