Author Topic: Shakey vacuum reading?  (Read 1772 times)
Offline AMXguy
« on: June 23, 2008 - 12:26:17 PM »
While trying to tune the fresh 383 in my buddy's Charger we notice about a 3 in quiver in the vac reading, is this a sign of a vac leak on an intake port? it idles with about 18 in. another thing I was wondering is does it matter where you take the reading? it's hooked to the brake vac tree.
 It runs fine but he doesn't want a lean cylinder causing a problem.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline moper
Re: Shakey vacuum reading?
« Reply #1 on: June 23, 2008 - 05:13:24 PM »
at 18" the thing should be rock steady IMO. I like to use the carb manifild vacuum source. The PB one only really "see" one cylinder.
Offline Robb
« Reply #2 on: June 23, 2008 - 05:58:33 PM »
sticky valve ?
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
« Reply #3 on: June 24, 2008 - 03:34:48 AM »
is the brake booster leaking internally ?
Offline wally426ci
    • maryland mopars
« Reply #4 on: June 24, 2008 - 04:00:29 AM »
 :popcorn:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #5 on: June 24, 2008 - 08:13:30 AM »
A three inch fluctuation (between 12 & 21 inches) may indicate that one or more valve springs are weak or broken. Does the fluctuation change as engine speed is increased? if so this might indicate worn intake valve guides. A slightly smaller fluctuation but with a normal vacuum condition (which seems to be what you have) may indicate an ignition problem. Check your coil, dist cap, plugs & plug wires ect. Let us know what you find. I hope it's something simple!! :2thumbs:
        Matt B.
Matt
Offline AMXguy
« Reply #6 on: June 24, 2008 - 09:34:47 AM »
We'll try to mess with it again today, he's got a new everything, booster,ignition( Mopar electronic ), everything new in the engine including valves , guides and springs.  it runs real nice and probably this never would have been noticed other than because we were trying to set the idle mixture with the vac gauge.
  we'll move vac gauge to the carb port and see if that makes a difference. my first though was a manifold leak, but a rag over the carb slows the idle so I don't know.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline BIGSHCLUNK
« Reply #7 on: June 24, 2008 - 11:47:51 PM »
Just a thought?/  :dunno: Lopey cam/lopey idle /lopey vac reading??  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
