Author Topic: more head combo questions  (Read 615 times)
Offline mikerallye
« on: June 23, 2008 - 02:00:21 PM »
What is the compression on stock 73 340? What is a "J" head? Can I up compression by changing to another year or type head? thanks
Offline moper
Re: more head combo questions
« Reply #1 on: June 23, 2008 - 05:12:07 PM »
'73 when measured typically is in the 8.2:1 range. J head is stock open chamber 1.88 intake design. Same as all others. Best way to gain squeeze is closed chamber such as Magnums. I dont like using the smaller LA port closed chambers on 340s. You cna also lose .4 by runnign the MP thin head gaskets.
« Reply #2 on: June 24, 2008 - 03:32:15 AM »
not much you can do , the 340 /360 headsa are approx the same volume & the smaller 318 heads don`t help the flow , the 318 /302 casting would be the best to use
Offline Rob C
« Reply #3 on: June 24, 2008 - 09:57:13 PM »
Mike, to up the ratio, theres the above mentions. Though I think the "302" head is a bad move. One left out, and I'm not the biggest fan of, is milling the head. You can go .060 on the heads deck for a big bump up for pump gas.
I'd rather see a Magnum head swap or a milling of the head.
'73 Cuda, 360, 4psd & 4.10's
'79 Dodge Magnum, 360, 727, 9-1/4 W/3.55's
