Author Topic: Draws in air between headers and pipes.  (Read 3099 times)
Offline Ornamental
  • Oslo, Norway
Re: Draws in air between headers and pipes.
« Reply #15 on: June 26, 2008 - 01:55:26 PM »
I would never weld the pipes to the headers...If you ever have work on heads or anything else where the exhaust is blocking access, you will hate yourselfs for doing so... :faint:
If you straighten the flanges and weld the flange to the header ( just some strong tagwelds between the boltholes ) you will gain a lot of strength , and you won`t have to take the flanges off the headers, which save a lot of work and time.  If you decice to go this way you have to make sure you have access to all 3 bolts for wrenching... :biggrin:
Yeah, I've decided to not have them welded after all, even if it's the quickest, simplest, and cheapest short-term solution.
I just know some $hit will happen then, that requires the headers to be removed.
It never pays to ignore the Law of Things Inherent Evil. :nono:
So tomorrow morning, I'll probably go to the muffler shop again, and wait for a turn. See if I can have the old flanges straightened out.
If not, I must try to persuade some metal workshop to make me four flanges the same day. Not very many of those in or near Oslo, according to google.
I have an extra set of TTI header reducers if you want them.. 2.5"
Thank you very much man, but I got a 3" collector.
Besides, TTI stuff on those pipes would be pearls before swine.  ;)
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline jvike
  • Pro-Touring Cuda
« Reply #16 on: June 26, 2008 - 02:18:54 PM »
Yeah, they're Header reducers.. 3" collector --> 2.5" outlet. From the picture it looks like you have a 2.5" system...
Offline Ornamental
  • Oslo, Norway
« Reply #17 on: June 26, 2008 - 02:47:38 PM »
Ok, I just misunderstood you.  :)
I'll see what the muffler shop can do, and if I find out that some TTI 3" to 2.5" reducers would be handy, you'll hear from me.  :thumbsup:
***Per Arne***
Offline Ornamental
  • Oslo, Norway
« Reply #18 on: June 27, 2008 - 04:05:55 AM »
This is what the same guy who suggested welding came up with after I said welding was a no-go:
Costed 1,540 Norwegian Kroner (NOK) = 303.875 US Dollar (USD)
Not bad by norwegian shop prices.  :)
***Per Arne***
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #19 on: June 27, 2008 - 04:34:00 AM »
Bro!  I need to go to open a shade tree mechanic shop in your country!  $300 for that?  All you needed was a hack saw - a small torch - some wire coat hangers and your hardware.  WOW!  Chryco could make a killing there, he could be the first millionaire I know!  Im glad you got it figured out though, exhaust leaks suck!    :eek4:
Don
Member Since January 14, 2002
Offline Ornamental
  • Oslo, Norway
« Reply #20 on: June 27, 2008 - 04:44:38 AM »
Yeah, it's a lot of money for a small job, but without neither welding equipment, exerience, and a good place to do it, it's what I had to do.
Still, by local prices, it's acceptable.
***Per Arne***
