Author Topic: 22" or 26"  (Read 721 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
22" or 26"
« on: June 24, 2008 - 09:24:54 PM »
Hi. What size rads came in 70 cuda 318 cars, My measurment across is 21 1/2 across the opening, and 24 1/2  bolt hole to bolt hole for mounting. I what to put in a 69-70 code 340, what kind of rad do i need, inlet outlet etc, no a/c  Thanks
Offline elevenssc
Re: 22" or 26"
« Reply #1 on: June 24, 2008 - 09:36:37 PM »
If the information I was given is correct, the 22" rad came on 318 non-air cars, and smaller displacement engines.  The 26" rad came on 318 cars with air, and larger displacement engines.
I replaced my 22" with a 26" on my 70 cuda (non air).  I had to cut the radiator core support hole larger so the 26" rad would fit. (all the core in the air flow)  Radiator inlet is on the drivers side top, and outlet is pass side bottom.
Hope this helps...
Alaskan_TA
Re: 22" or 26"
« Reply #2 on: June 24, 2008 - 09:54:20 PM »
22" also came in 440-6 cars (and others) without AC or an axle package.
Re: 22" or 26"
« Reply #3 on: June 25, 2008 - 01:32:56 AM »
the rad you need is a 22" wide , minimum high efficiency 2 core  or 3 core with lower passenger side & upper drivers side hose connections
