Author Topic: Z-bar  (Read 1756 times)
Offline 71chmark
Z-bar
« on: June 28, 2008 - 06:45:31 PM »
I have a z-bar from a B body.  The rod going to the clutch fork is for an e body and is to short.  I cobbled together something that works  but would like it to be right.  Are the z-bars different from E to B.  I saw the pictures in the "4-speed help thread" and I couldn't tell a difference.
I may be schizophrenic,
Offline Changin Gears
Re: Z-bar
« Reply #1 on: June 28, 2008 - 07:40:54 PM »
What pedal rod do you have?  B-bodies are shorter and would cause this problem.
By the way "Z-bar" is one of those off brand Chevy terms like "posi".
Offline matt63
Re: Z-bar
« Reply #2 on: June 28, 2008 - 07:45:32 PM »
You can check out Brewer's website to see what parts are available.  They specialize in the 4 speed stuff.
Matt in Edmonton
'68 Valiant
Offline 71chmark
Re: Z-bar
« Reply #3 on: June 28, 2008 - 08:36:43 PM »
I probably have the B body pedal rod.  I gotsa posi too.  Thanks for the info.
Re: Z-bar
« Reply #4 on: June 28, 2008 - 09:57:28 PM »
Cut it and lengthen it
