Author Topic: Vin# on engine?  (Read 2326 times)
Tower Rat 95B
Vin# on engine?
« on: June 29, 2008 - 08:26:06 AM »
  Can the vin # on the engine give info on what type body the engine was originaly in?   The vin# down by the oil pan rail is     F199321            and the pad up by the distributer is stamped,,,,
                                              J 440         HP
                                              2          9
    I spaced that as it appears on the pad,,,,,,,,  does this info tell any thing about what year and body type it came from?
                     Thanks.............
Re: Vin# on engine?
« Reply #1 on: June 29, 2008 - 01:11:57 PM »
Yes & no , it gives the plant the engine was installled at & from that we know only certain models were produced at the plant , but it will not give you specific body type the engine came from
Offline Culvers
Re: Vin# on engine?
« Reply #2 on: June 30, 2008 - 11:02:02 AM »
                                              J 440         HP
                                              2          9
"J" would mean 1973
Offline ChallengerHK
Re: Vin# on engine?
« Reply #3 on: June 30, 2008 - 01:06:19 PM »
Doesn't apply in this instance, but a couple of years had the full VIN (i.e., not just the sequence number) stamped on the block.
- Han Solo, Star Wars
Tower Rat 95B
Re: Vin# on engine?
« Reply #4 on: July 01, 2008 - 07:00:58 AM »
Thanks fellas I do appreciate the help  :2thumbs:........
 So  it goes like this right?
 J= 1973
 440= obvious 440
 HP= High Performance
 2      9  =      Assembly plant?    Which plant?
 Since this is a 1973 440 hp it would most likely be a Road Runner engine so 2  9 would be a Road Runner assembly plant?
Offline Culvers
Re: Vin# on engine?
« Reply #5 on: July 01, 2008 - 10:47:26 AM »
2    9  = February, 9th
Alaskan_TA
Re: Vin# on engine?
« Reply #6 on: July 01, 2008 - 09:04:25 PM »
The assembly plant for the car it came out of will be on the VIN pad. Look on the passenger side of the block, about mid-engine (front to back) slightly above the oil pan rail.
Re: Vin# on engine?
« Reply #7 on: July 04, 2008 - 03:22:53 AM »
assy plant was F - Newark plant
Tower Rat 95B
Re: Vin# on engine?
« Reply #8 on: July 04, 2008 - 04:57:53 AM »
          Thanks nice to know what plant it came from,  but what state is  the Newark plant?    So if I was to search for a 70 date coded block  what would the the code for the Hamtrack plant be?  If you have a 70 car with a 10/69  build date does that mean you would have a 69 date coded engine?
Re: Vin# on engine?
« Reply #9 on: July 04, 2008 - 12:42:01 PM »
B is the Hamtramck plant
 yes a 10 /69 car would have a 6/69 block
 not sure where the newark plant is or what was built there
Offline NoMope Greg
Re: Vin# on engine?
« Reply #10 on: July 04, 2008 - 03:34:29 PM »
Newark is Newark, Delaware, closed last year.
http://cbs3.com/topstories/Chrysler.Plant.Employees.2.307421.html
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline 69coronetrt
Re: Vin# on engine?
« Reply #11 on: July 06, 2008 - 12:46:43 AM »
And a '73 440 out of the Newark plant would have come in a C body.
