Author Topic: Can you feel the difference from 323 to 355's?  (Read 1530 times)
« on: June 29, 2008 - 02:06:22 PM »
I Had 323's in my car----so/so.... I put 410's in it and loved it. I am sure it is good for maybe 2 tenths or more or better.  I put the 323's back in and wasn't happy.  I don't have to go over 3k on an interstate or cruisin.
I just had my dana 60 done, it has 354's in it. I am wondering if maybe I should step back up to 410's?  I used to run 11.98 with my 355's many years ago in my street car and a 440 with an automatic, but I had a 4500 turboaction stall and it took care of slow out the hole. I have a 4spd now, and 28" tall tires.
Just trying to get the low down before I install the rear. I may be doing a gear change :cheers:
Re: Can you feel the difference from 323 to 355's?
« Reply #1 on: June 29, 2008 - 02:19:30 PM »
yes you will feel the difference , as for what is the right move only you can decide
« Reply #2 on: June 29, 2008 - 02:28:40 PM »
Al,
  If you don't plan to highway cruise with this, and are just interested in racing it... it sounds like 4:10's are your ticket.   :grinyes:  The 3:54's sound like a nice compromise if you want to do a little of each.
Offline Katfish
  • 70 Challenger
« Reply #3 on: June 29, 2008 - 04:11:58 PM »
I think there are aftermarket 3.73 or 3.91's available.
Offline Changin Gears
« Reply #4 on: June 29, 2008 - 04:41:00 PM »
The stick won't be as bad as the auto on the highway - no converter slip.  You can always run 28" tires on the highway and 26" sticky tires at the track.
nivvy
« Reply #5 on: June 29, 2008 - 05:21:03 PM »
3.91's are the best all around gear  :2cents:
Offline ntstlgl1970
  • T a c o c a t
« Reply #6 on: June 29, 2008 - 07:46:02 PM »
Kinda like that idea myself if you don't want to go back to a steep gear
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #7 on: June 29, 2008 - 09:06:26 PM »
if you never drive over 60 mph
« Reply #8 on: June 29, 2008 - 09:43:07 PM »
Old hp mopars were really not intended for highway speeds unless they were equipted with 323 gears. I wont be interstate driving, I live in the country. So 60 is ok untill I need wot. But I will install the 354's for now and then latter swap to the 410's. I also like 391's in a bb street car. They work very good.  I always used a rule of the thumb, 3k while cruising whatever the speed with larger gears.
« Reply #9 on: June 30, 2008 - 02:02:48 AM »
ord offered the 3.73 gears for the Dana , could be the best choice ???
