Author Topic: when i turn my signal on left or right its real sloppy whats up  (Read 1067 times)
Offline geneo4116
  • 70 rt 383 auto blk/blk apprx 450hp
70 challenger turn signals work but where it goes into the colum the chrome lever is real sloppy is this an easy fix or a headache, cause they work fine ,any way apperciate any responses thank you :feedback:
Offline LAA66
Re: when i turn my signal on left or right its real sloppy whats up
« Reply #1 on: June 29, 2008 - 11:34:56 PM »
 The headache is, you will need to pull the steering column to get to the mechanism. It's easy with the proper tool though. If the plastic isn't cracked simply tighten the pivot screw a bit.
Offline geneo4116
« Reply #2 on: June 30, 2008 - 12:42:51 AM »
whats the prorer tool and how is it done
« Reply #3 on: June 30, 2008 - 01:57:26 AM »
you either need a small steering wheel puller to fit inside the crush can or a long enough one to reach into the can to pull it off once it is off you need a 5/16" nut driver to tighten the arm
