Author Topic: Edelbrock linkage  (Read 3445 times)
Offline shatar4
  • 71 Challenger
Edelbrock linkage
« on: June 30, 2008 - 01:49:21 PM »
Trying to setup my kickdown and throttle cable but was wondering what everyone was useing? Is there a kit that is avaliable to hook these up? Picture would be great also. Thanks
1971 Triple black 340 Challenger
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Edelbrock linkage
« Reply #1 on: June 30, 2008 - 02:06:14 PM »
Edelbrock sells a bracket for their carbs for the Mopar kickdown linkage. Here it is on Summit's website
http://store.summitracing.com/partdetail.asp?autofilter=1&part=EDL%2D1481&N=700+4294925239+400065+115&autoview=sku
1996 Dodge Viper GTS Coupe
Offline shatar4
  • 71 Challenger
« Reply #2 on: June 30, 2008 - 03:12:03 PM »
Thanks, that's what I needed!
Offline jvike
  • Pro-Touring Cuda
« Reply #3 on: July 01, 2008 - 05:06:21 PM »
I have the above with an Lokar cable setup.
Offline GoodysGotaCuda
« Reply #4 on: July 01, 2008 - 08:29:53 PM »
I have the lokar setup above too
1976 Dodge Warlock
Wheel & Tire Specs:Link
nivvy
« Reply #5 on: July 01, 2008 - 09:52:13 PM »
I use to have the lokar setup on my dual quad edelbrock setup....... excellent piece... BTW the kickdown is useless with a MVB ...  :smilielol:
Offline skid440
« Reply #6 on: July 02, 2008 - 12:09:48 AM »
 70 Challenger RT 440 Edl. 800cfm. ---Can anyone describe to me how to set up the kickdown linkage?   The yellow bible is confusing to me.  I get that you want the tranny lever at the forward stop but from there I dont get it.  Do I adjust the slotted piece that connects to the carb so it just rests at the post in the rear or front of slot.  Do I do wot ant then adjust from there?  Any help or pics would be great.  John
« Reply #7 on: July 02, 2008 - 01:45:19 AM »
you want the kickdown linkage to move all the way back with the carb @ WOT , you need a spring on the kickdown to pull it forward at idle
Offline skid440
« Reply #8 on: July 02, 2008 - 11:00:35 AM »
Thanks Chryco,
I have that spring but not pictured.  I have all the pieces except for the rod-to-lever clip for the transmission lever.  NAPA has an aftermarket one but only as big as 1/4 and that rod is larger than that.  Do you have a solution?
Someone in my restroation thread said I can zip strip it rearward temporarily so I can drive.  Do you agree?
Skid
« Reply #9 on: July 03, 2008 - 03:37:20 AM »
as long as the rod stays in the lever yes I agree , not sure where to find the clip you need though
Offline mikerallye
« Reply #10 on: July 03, 2008 - 09:26:33 PM »
Here is the mount on my 440. It came from a 71 imperial, but works fine. The bracket is held down by the intake bolt in  the pic. Kinda small pic; should be able to figure it out.
Offline skid440
« Reply #11 on: July 05, 2008 - 08:11:12 PM »
Thanks for the pic MikeRalleye.  The part I was referring to is down at the transmission.  I just put a jam nut on the tip of the rod to keep it there.  But mopar had a more substantive bracket.    Now I am trying to adjust the position of the kickdown.  I put the back end (toward firewall) of the lever at the stop at WOT.  It is beginning to shift now so that is better than starting out in third but it shifts into third at about 20mph.  Do I need to move it more forward or rearward?  Thanks  Skid
« Reply #12 on: July 06, 2008 - 01:00:30 AM »
the kickdown needs to move back more to shift at higher Mph
