Author Topic: HELP! Oil pan removal  (Read 2493 times)
Offline hemidude426ci
« on: July 01, 2008 - 10:09:03 PM »
Gentlemen,
So I am removing my oilpan to install a more ground clearance friendly factory style pan on my new 'Cuda.  I got the pan off alright, but I am having difficulty with the steering arm that goes right under the pan and connects the tie rod ends, it will simply not come out. Any tips???
1970 FC7 440-6 'Cuda 4spd  Track Pack N96
Gone:
1970 Challenger R/T 440 6pack 4 spd N96
1970 Superbee 440 6pack 4 spd
1967 Shelby GT350
Offline Changin Gears
Re: HELP! Oil pan removal
« Reply #1 on: July 01, 2008 - 10:25:51 PM »
Sounds like you are going to have to bite the bullet and drop the steering center link.  You can unbolt the idler arm, but need a puller for either end of the pitman arm.
Tower Rat 95B
« Reply #2 on: July 02, 2008 - 04:33:38 PM »
 I think its called a Pickle Fork,  I bought one for the exact same job just put it between the two joints and a couple of good wacks with a mini sledge and it will seperate .........  those rubber grease cups will probley get torn and need to be replaced.........
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: July 02, 2008 - 04:44:09 PM »
you can rent a pitman arm puller at most autozone stores, might be easier than taking a chance with a pickle fork....
Offline BIGSHCLUNK
« Reply #4 on: July 02, 2008 - 06:10:55 PM »
Out in the yard my guys usually can get'm apart just by giving it a couple of good wraps on the side. Therefore saving the boot. A pickle fork will tear the boots!  :bigsmile:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #5 on: July 02, 2008 - 06:53:52 PM »
So there's basically no way around it huh?
Gone:
1967 Shelby GT350
Offline NoMope Greg
« Reply #6 on: July 02, 2008 - 07:38:52 PM »
Nope.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #7 on: July 02, 2008 - 08:12:17 PM »
Have you tried lifting the engine up?
1970 Dodge Challenger
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
Tower Rat 95B
« Reply #8 on: July 02, 2008 - 10:27:47 PM »
 Its a piece a cake the tool is like 20 bucks and a few bucks more for the boots,  ya could probley even rent the tool for free at AZ or Advance.......
« Reply #9 on: July 03, 2008 - 03:43:43 AM »
there are also tool s for popping them apart with damaging the boots & I usually seperate them with 1/2 dozen hard raps with a heavy hammer
