Author Topic: Between Coats  (Read 758 times)
Offline basement
Between Coats
« on: July 02, 2008 - 09:46:09 AM »
From my recent posts you may have guessed that I am new at the painting side of working on cars. And hope you don't mind another dumb question. I've finished priming my parts and about to spray the base coat. I know I need to rough up the primed surface with some 400grit paper but should I also wipe it down again with wax and grease remover or would that be to aggressive of a cleaner? Or would wiping it down with water be good enough?
Offline ksierens
    • 70 Challenger Resurrection
Re: Between Coats
« Reply #1 on: July 02, 2008 - 10:46:37 AM »
Yes, alway use a wax and grease remover before painting.  :thumbsup:
Kurt - SE Michigan
Offline todd383
  • I'm a llama!
Re: Between Coats
« Reply #2 on: July 02, 2008 - 09:41:51 PM »
I would go over the 400 grit paper with 600 grit , 400 is way too coarse,esspecially if it a metalic paint.. Trust me,  i have been doing body and paint work for 25+ years!!!
Offline ksierens
Re: Between Coats
« Reply #3 on: July 03, 2008 - 07:12:13 AM »
Todd, I am going to shoot my engine compartment, jambs and trunk with black, would you use 600 there also?
Kurt - SE Michigan
Offline ntstlgl1970
  • T a c o c a t
Re: Between Coats
« Reply #4 on: July 03, 2008 - 02:50:47 PM »
I agree with Todd, go with 600, even in the engine compartment. Wipe it down and use a tack rag too.
