Fatties are on !!! More 315 action
Author Topic: Fatties are on !!! More 315 action  (Read 7128 times)
Offline Boydz
  • 1972 Barracuda R/B
    • Ryan's Cuda
« on: July 02, 2008 - 11:33:50 AM »
Ok, so after much :clueless: and reading all of Mike Tylers (thanx Mike) and others posts regarding stuffing these 315's under the back of my Cuda, I finally have accomplished this task. I ended up going with a set of aftermarket wheels for a late model mustang (94-04) because they were much cheaper as a package than custom wheels. As you can see by the pics they fit quite nicely and do not rub unless you really bottom the suspension out hard, but normal driving seems to be fine along with hard cornering and acceleration. I am in the process of getting some different center caps and ditching the cobra ones  :eek4:
Here's the specs
Rear's - 17x10.5 with Sumitomo HTRZ 315/35 ZR17  - +27mm with 6.9"  backspacing - no spacers
Front's - 17x9 with 245/45/17 - +24mm with 5.95" backspacing with a billet 1" wheel spacer/adapter from http://www.wheeladapter.com/home.asp I dont normally like spacers, but I have run these for 4 years now on my other rims with no issues at all. They never shifted, loosened, nothing but rock solid.
With the 9" wheel I could probably fit a 255 up front, but it would be close to the frame. I have roughly 3/8" of room now between the tire and frame at full lock now and still have room to clear on the outside. I would like the look of a wider tire on the rim, but the 9" is just too much I think for anything bigger than 255's or so.
I also installed the 1.5" DR. Diff spring relocation kit which installed perfectly. This is a very nice kit and is very well made (Thanx DR. Diff !!! :worshippy) The hardest part of this was removing the spring perches and re-welding them. During this process I re-centered them and also moved them back a bit to increase the pinion angle a few degrees down since I lowered the car. I did end up using 1" blocks in the back and had to sand a slight angle on them to get the pinion angle just right at around 5deg down.
As you can see in the pics, I still ended up with more outside lip clearance on the drivers side then on the passengers even though I repeatedly tried to get it to sit centered in the car. Apparently this is where it is happiest so I went with it. It’s really only off by 1/8 to 1/4" toward the passenger side and it still doesn’t rub on anything anyhow, not to mention I figured a bit more clearance on the drivers side would allow for some flex room under hard acceleration.
As far as inside clearance I am about 3/8" to 1/2" away from the springs and about 1/2" to 3/4" (depending on which side) away from the inner fender wheel wells. I will try and post some pics of the underside when I get a moment, but everything really clears nicely.
One other thing to mention is that these wheels are (were) hub centric and I had to massage the rear hub opening about 1/32 for the rears to fit :banghead:. I took a slight amount off with a dremel tool being very careful to keep things even. this didn’t seem to affect anything and I don’t notice it while driving so I think we are all good.
My rear valance fit back on without much trouble. The shackles do lay on it just a touch but its not really rubbing it and definetly not denting it or anything like that so I think this is about as close as it gets without modification. This is the only re-pop panel on the car so maybe this is why it fits? Either way, all good for me – Whoo Hoo !!! :bananasmi
Anyhow, Thanx to everyone  :worshippy who has posted in the past with good and bad experiences and successes and failures. It has been truly helpful for sure!!!!
And yes I have pics :)
« Last Edit: July 02, 2008 - 12:56:18 PM by Boydz »
Offline GoodysGotaCuda
Re: Fatties are on !!! More 315 action
« Reply #1 on: July 02, 2008 - 11:41:53 AM »
Pics aren't workin!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ksierens
    • 70 Challenger Resurrection
« Reply #2 on: July 02, 2008 - 12:11:30 PM »
Yes, pics no workie! Wanna see!
Kurt - SE Michigan
Offline Boydz
    • Ryan's Cuda
« Reply #3 on: July 02, 2008 - 12:36:11 PM »
Thats wierd, they work in the preview and if you copy and paste the image address into the browser. Is there a limitation on size here ?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: July 02, 2008 - 12:43:25 PM »
yes, you need to resize them under 300kb.  Or link them to another site.
Tom :picture:
Tom
Offline Boydz
    • Ryan's Cuda
« Reply #5 on: July 02, 2008 - 12:58:01 PM »
Ok - Try that :)
I moved them from the photo hosting site. They were all under 300k so who knows what the problem is. i definetly wanted to link them outside this site since I hate when I come across posts that are i year old and all the pics are missing ;)
Offline 71bigblock
    • Steve's Mopars
« Reply #6 on: July 02, 2008 - 01:11:32 PM »
Holy smokes, that looks nice!   :bananasmi
Offline ksierens
« Reply #7 on: July 02, 2008 - 01:17:36 PM »
Kurtie likee!  :bananasmi
Kurt - SE Michigan
Offline NoMope Greg
« Reply #8 on: July 02, 2008 - 01:42:17 PM »
Sweet!  Looks great!  :2thumbs:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline ChallengerGary
    • Challenger Gary
« Reply #9 on: July 02, 2008 - 01:46:38 PM »
 :wow:  :wow: That is a perfect look for your car!  You NAILED IT!!
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline Blown70
« Reply #10 on: July 02, 2008 - 01:55:05 PM »
 :2thumbs:  NICE love that look :wow:
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« Reply #11 on: July 02, 2008 - 02:07:04 PM »
Super nice  :2thumbs:
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #12 on: July 02, 2008 - 02:37:22 PM »
Quick question for you, do the Ford wheels make your car slower? :roflsmiley: Just kdding the wheels look great and fit very nice on your car. :thumbsup:
1996 Dodge Viper GTS Coupe
Offline Carlwalski
« Reply #13 on: July 02, 2008 - 03:51:35 PM »
Looks great mate from the rear just not a fan of the low profile rims for looks and traction.
Still, she should handle real good on the tire side once under way, nice work and good photos.
:cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Boydz
    • Ryan's Cuda
« Reply #14 on: July 02, 2008 - 04:04:56 PM »
Thanx Guys,
I appreciate the nice comments !! It definetly was a bit nerve racking trying to get everythinbg figured out. Not like you can return stuff once you start hacking it up :)
Carlwalski,
Im a fan of bigger tires too, unfortunaetly its hard to get both so I decided that what I loose in height, Ill make up for in width :burnout: :ylsuper:
