Pretty sure the dowels line up fine, but im not sure about the crank hole, does the truck input shaft have a longer snout that goes into the crank than a car? That would be the only thing that would make sense. Other than pulling the motor out and goin through everything to drill the crank deeper, is there anything I can do? Does anyone make a spacer plate that is say 1/8 or 3/16 inch, and would I run into any big problems if I bought one or made one up. Also maybe have the input shaft machined about 1/4 inch, maybe a hair less?
