Author Topic: Alternator test  (Read 1796 times)
Offline cuda-cable
  • MOPAR or no car
Alternator test
« on: July 03, 2008 - 09:16:40 AM »
What's an easy test to check the output of my alternator, i have a volt meter wired direct to battery but see only 12 volts, drops to 11 with headlites/heater on. I never see anything greater, just started driving car last week, but don't want to get stranded with a dead battery far from home if my alternator isn't charging. I don't have a 'large wire' ground from engine to frame? could that be my problem?......will try that in the interim.......thx.....dk
Offline matt63
Re: Alternator test
« Reply #1 on: July 03, 2008 - 10:56:27 AM »
You can check the alternator output voltage at the big lug on the alternator.  It should be about 13 to 13.5 volts depending on the regulator.  Many common repair shops or battery places can do a load test on the charging system too.
Matt in Edmonton
'68 Valiant
Re: Alternator test
« Reply #2 on: July 03, 2008 - 11:46:01 AM »
you should be as high as 14.2v , did you try revving the engine with the voltmeter connected ?
Offline FY1 RT SE
Re: Alternator test
« Reply #3 on: July 03, 2008 - 03:25:34 PM »
Do you have good grounds at the voltage regulator and at radiator support?
Offline cuda-cable
  • MOPAR or no car
Re: Alternator test
« Reply #4 on: July 04, 2008 - 12:22:05 PM »
folks,  thx for all the good suggestions, I've added a #1Ga ground from my engine block to the frame......things are much improved, dash lites in particuliar and I'm showing 14+ v on my gage. You folks are a huge help......thx......dk
Re: Alternator test
« Reply #5 on: July 04, 2008 - 01:48:19 PM »
Congrats!!
   You definitely nailed it!!   :clapping:   :woo:   :woohoo:
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: Alternator test
« Reply #6 on: July 04, 2008 - 08:52:03 PM »
if that helped I would check the main ground cable from the battery to the block- if it is really old it could have some resistance inside the cable.
Offline inot2old
Re: Alternator test
« Reply #7 on: July 04, 2008 - 09:41:03 PM »
Glad your problem was just a ground.  I had the same problem, & ended up replacing the voltage regulator which solved it.
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
