Author Topic: Antifreeze  (Read 2279 times)
Offline old-school
Antifreeze
« on: July 04, 2008 - 11:07:18 AM »
Are you supposed to run straight antifreeze in your radiator or add a little water to the mix? Also, what type of antifreeze is best for our big blocks? Thanks
nivvy
Re: Antifreeze
« Reply #1 on: July 04, 2008 - 11:19:12 AM »
I run 50/50 anti freeze..
Re: Antifreeze
« Reply #2 on: July 04, 2008 - 11:34:15 AM »
You get the greatest range of temperature protection and corrosion prevention by using a 50/50 mix.
Offline GoodysGotaCuda
Re: Antifreeze
« Reply #3 on: July 04, 2008 - 11:34:46 AM »
Never run straight anti-freeze. I run 70% distilled water/30% coolant.
Depends on your climate.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline moparmaniac59
  • Drive it like ya stole it!
Re: Antifreeze
« Reply #4 on: July 04, 2008 - 01:27:28 PM »
I've never run straight antifreeze, but I've heard that straight antifreeze (no water added) can actually freeze. Anybody else heard this?? :clueless:
                                                    Matt B.
Matt
Re: Antifreeze
« Reply #5 on: July 04, 2008 - 02:16:25 PM »
                                                    Matt B.
Matt,
  It's actually the opposite. Water has a far better cooling ability over anti-freeze. The problem is, water freezes and corrodes. Anti-freeze doesn't corrode, or freeze, but...is far less able to "get the heat out of the kitchen" than water. So a 50/50 mix of anti-freeze and distilled water fits most folks.
Offline old-school
Re: Antifreeze
« Reply #6 on: July 04, 2008 - 04:14:14 PM »
Thanks everyone for all of the opinions! The resources on this website are awesome!
Offline Aussie Challenger
Re: Antifreeze
« Reply #7 on: July 04, 2008 - 09:55:15 PM »
  Using tooo much anti freeze causes more problems than it solves. The anti freeze can actually cause corrosion especially on any aluminum parts, I have had water pumps fail due entirely to tooo much anti freeze.   :22yikes:
Offline MrMopar440
Re: Antifreeze
« Reply #8 on: July 05, 2008 - 03:54:37 AM »
Along the same lines - Has anyone here run the Royal Purple additive (Purple Ice  - or something like that)? It is supposed to lower the surface tension on the water/antifreeze mix and allow better cooling. I know that there are a few products out there that are similar, but I only have easy access to the Royal Purple line. Thoughts? :dunno:
Re: Antifreeze
« Reply #9 on: July 05, 2008 - 04:36:02 AM »
the coolant additives to increase cooling do work but are less effective with higher percentages of antifreeze
Offline Changin Gears
Re: Antifreeze
« Reply #10 on: July 05, 2008 - 08:40:58 AM »
Water is a beeter thermal conductor than anti-freeze so if you run 100% anti-freeze you are more likly to overheat.  But, anti-freeze has a higher boiling point which would make it boil over at a high temp.  Sort of a double edged sword.
I use somewhere between 70/30 and 50/50.
Offline go-fish
Re: Antifreeze
« Reply #11 on: July 05, 2008 - 02:17:59 PM »
This is broken down for Old-School. He is a self proclaimed non-mechanic so I want to help him in any way I can. You have to start somewhere in this hobby, right? Here goes some basic coolant/anti-freeze tips:
If you go to any parts store you will be able to find an anti-freeze tester. It is a clear plastic thing with a tube that goes in your coolant/anti-freeze and has a little rubber squeeze thing on the other end. When you pump the rubber pump thing it will suck a sample into the clear plastic part and little tiny balls will float around and tell you what your mixture protects your engine to (degrees wise).
Just ask them for an anti-freeze tester. Also, never pour your anti-freeze in and then water on top of that. Pre-mix to ensure thorough mixing. They sell anti-freeze/coolant premixed with distilled water, it is a simple solution. Remember to use distilled water too.
« Last Edit: July 05, 2008 - 02:22:52 PM by go-fish »
Offline old-school
Re: Antifreeze
« Reply #12 on: July 07, 2008 - 07:17:15 PM »
Thanks go-fish! I appreciate all the comments.
Re: Antifreeze
« Reply #13 on: July 07, 2008 - 09:42:43 PM »
OK,
I am not crazy.  :screwy: Antifreeze alone with no water added will actually freeze at about 8 degrees fahrenheit. Really, it's true!! Here's some info I puuled from a science web site:  Ethylene glycol, the principal component of most antifreezes, freezes at 8 degrees above zero (fahrenheit). It is only when WATER is added that the freezing point is depressed. The freezing point of an ethylene glycol and water mixture drops rapidly as the concentration of glycol is increased to a mixture of about 60% antifreeze and 40% water. Around that point, an abrupt turnaround occurs, and as more antifreeze is added, the freezing point rises almost as fast as it had previously dropped. I've never seen an antifreeze container with a note to this effect. So there you have it. It is clearly a case of what you don't know that can hurt you. Thom Wigle of Dow Chemical in Ontario says that his office get several hundred complaints each winter from irate customers complaining that their antifreeze is "No damn good.". A typical story is that the customer was using a Dow product undiluted and their engine froze up at around zero (fahrenheit). So NEVER run your engine with a concentation of antifreeze/water above a 60% ethylene glycol mixture. Too much antifreeze is not good. This has nothing to do with the heat transfer/cooling properties (that's a different subject). Simply the ability of antifreeze from keeping your coolant from freezing!! Your science lesson for the day!!! :bigsmile:
                                                              Matt B.
Matt
Re: Antifreeze
« Reply #14 on: July 07, 2008 - 11:40:01 PM »
OK,
                                                              Matt B.
I never new that, looked it up myself, your right.
« Last Edit: July 08, 2008 - 08:22:52 AM by Changin Gears »
