Author Topic: Ok Plug guru's,I need your help -UPDATE- again  (Read 10784 times)
Offline BIGSHCLUNK
« on: July 05, 2008 - 11:50:29 AM »
Ok, I know my tach dosen't read right.  :screwy: So I moved on to some tuning isses (which I admit I'm  :crying: not good at). I currently have the timing at 8-10 BTC. I changed the vaccum routing on the dist from the port on the side of the carb to the port on the base. (750 DP Holley). Seems to have improved performance .  :grinyes: So now to try readjust the carb... the ol' vaccum gage and tach (SEARS) method. Jumpy tack/and needle on vac gauge. Cap and rotor looked good so I pulled plugs. First pic is left bank front to rear. Second pic is right. Lots of variation in color. # 2 on right bank  :puke:  Give me your  :2cents: please!
Would help if I posted the pics,,,  :screwy:
« Last Edit: July 06, 2008 - 11:04:02 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Ok Plug guru's,I need your help
« Reply #1 on: July 05, 2008 - 12:03:47 PM »
Yikes
 ok so let me get this straight , you have a 750 CFM carb on a 426 Hemi when they cam factory with over 1000 & you are running the new single 4 bbl dual plane intake & from what I can see #5 on the left side & 2&8 on the right side are too lean , the logical explanation here is that 3 of the 4 lean plugs are fed by the 1 plane of the intake indicating that one side of the carb is set too lean & also the manifold has poor distribution or all 4 plugs should be that lean
Offline BIGSHCLUNK
« Reply #2 on: July 05, 2008 - 12:21:16 PM »
Chryco, this is what was on it when I bought it. Can you point me in a direction, I figure new plugs??  But what after that?? Oh and THANKS in advance.
Here's a pic..
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #3 on: July 05, 2008 - 12:40:54 PM »
ok so it looks like the lower plane is causing the problems which is fed from the right side of the carb , , I would start by evening out the mixture screwws on the left & right side of the carb , make sure they are both out the same # of turns , then maybe pull off the front fuel bowl & make sure the jets are the same on both sides , this will require new gaskets
Offline BIGSHCLUNK
« Reply #4 on: July 05, 2008 - 12:49:55 PM »
Will do! I know the jets are thye same because I had that apart last year. But don't remember the size. I will play some this afternoon. And post results later. A thousand thanks!  :worshippy
BTW... should a bigger carb be in my future?? I have no idea what was on her originally.  :dunno:
« Last Edit: July 05, 2008 - 12:51:56 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline 71chally416
    • The Streetwalker
« Reply #5 on: July 05, 2008 - 01:13:16 PM »
I wouldn't put a Champion plug in anything but my lawnmower. I don't know how useful it is to look at plugs that old out of a motor that was idling. Racers usually make a full 1/4 mile pass with fresh plugs and then cut the motor clean and pull them out at the end of the track and look at the base of the porcelin with a lighted magnifying glass to check the jetting
 http://www.dragstuff.com/techarticles/reading-spark-plugs.html
nivvy
« Reply #6 on: July 05, 2008 - 01:18:41 PM »
X2 I ran those RC12yc plugs and my 499 likes the autolite 3922's alot better... however as soon as i saw the plugs i thought unevenen distribution as well..... good luck    :working:
« Reply #7 on: July 05, 2008 - 02:38:29 PM »
A 750 is small for a Hemi.   :2cents:
Offline BIGSHCLUNK
« Reply #8 on: July 06, 2008 - 12:06:20 AM »
Way back when I got her I posted that I didn't think she was that fast (being a HEMI car). People thought I was nuts!!!  :grinyes:   I would assume??? .... bigger CFM would really enhance her performance...
So whats the carb recomendation Holley 1000 DP??  :dunno:  Any imputs appriciated on this, remember I'm in the business of taking them apart... tuning/setup wise I don't know  :poopoke: minus the poke part!
Anyway, I got the plugs  changed and reset the mix screws. Now they are all turned out approx 1 1/2 maybe 1 3/4 turns out. Any farther out and I start using idle quality (if you can say that on a HEMI  :clueless: ).
At idle she actually smells a bit rich now. But seems to be better drivability wise. I left the timing where it was.
71 & Stroker,  I have a tendency to agree on Autolites over Champs, but they were in there when I got her. Been a while time wise, but not miles wise.
Thanks for your imput guys I really do appriciate it!  :2thumbs:
Any other thoughts welcome!  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline hemiken
Re: Ok Plug guru's,I need your help -UPDATE-
« Reply #9 on: July 06, 2008 - 12:12:29 AM »
Hi Bigs,
Have you got any info of what the camshaft is in your Hemi old mate :2thumbs:
Offline matt63
« Reply #10 on: July 06, 2008 - 12:21:03 AM »
8-10 BTC?  Sounds like you need a lot more initial timing.  This would cause some richness.  The 750 should be fine except for top end/WOT. CP?
Matt in Edmonton
'68 Valiant
Offline BIGSHCLUNK
« Reply #11 on: July 06, 2008 - 12:22:37 AM »
Hi Bigs,
Kenny , I'm guessing it's the one it came out of the crate with?? But I have no way of knowing for sure. I do know that someone was in the timing chain cover at one time tho... because I had a front seal leak. When I took it apart I found the front seal was a bit cocked. Put the new seal in (seated correctly) and no leaks! Actually I could swear when I fixed it, that it brought my oil press up a little...  :screwy:
I'm open to suggestions for sure!  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline hemiken
« Reply #12 on: July 06, 2008 - 12:29:23 AM »
So if it is the standard Mopar grind cam for the 426 Hemi crate motor it is listed at 278* and .495/.480 lift hydraulic. I would suggest stepping up or borrow an 850 double pumper to try out. :2thumbs:
Offline 71chally416
    • The Streetwalker
« Reply #13 on: July 06, 2008 - 12:33:59 AM »
If you really want to get a great carb that's tailored to your combination and will need minimal tweaking, you can't do any better than ProSystems and they don't cost that much more than a new Holley. They can also modify yours.
http://www.pro-system.com/
The Edelbrock EPS 800 is another great street carb. We did a back-to-back test on an engine dyno with a pretty well built 440 (big solid cam and ported aluminum heads) and one of those made within 5hp of a 850 DP Holley, but for sure the EPS is alot more streetable and has all the parts available to tune it. My 2 cents.  :2thumbs:
Offline BIGSHCLUNK
« Reply #14 on: July 06, 2008 - 12:42:49 AM »
Stepping up is not an issue thats for sure.  :thumbsup: Want to make the right choice the first time tho! Seems the Holley I have is very easy to work on. And parts are available locally so I don't need to call Jegs or Summit. Not familiar with pro-system but MINIMAL tweaking is good for me!!  :grinyes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
