Author Topic: Volt Meter Gauge Question  (Read 1015 times)
Offline MJS73
    • Mike's 1973 Challenger
« on: July 06, 2008 - 10:50:49 AM »
I have a question about my gauge reaction.  I had the ammeter converted to a voltmeter at Redline.  They said that they calibrated it so that the needle should point straight up to 12:00 during normal operation.  When I start the car, the needle stays all the way to the left.  After a short time (5-10 seconds) the needle comes up to where it should be and acts normally.  Is this "dead" needle at startup normal behavior?
MJS73
www.mikes73.com
Offline matt63
Re: Volt Meter Gauge Question
« Reply #1 on: July 06, 2008 - 11:15:27 AM »
No.  The voltage should be there instantly and the gauge should read it instantly.
Matt in Edmonton
'68 Valiant
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #2 on: July 06, 2008 - 11:52:32 AM »
this is normal as when you start the car you have drained the battery a bit- so when the alt & reg start to charge back into the battery - it will read a bit high until the voltage stablizes and the volt reg will then drop back to where it is normal!
« Reply #3 on: July 06, 2008 - 01:14:45 PM »
I wouldn't worry about it.   :grinno:
