Author Topic: Which 440 do I have?  (Read 5289 times)
nivvy
Re: Which 440 do I have?
« Reply #15 on: July 07, 2008 - 02:53:08 PM »
This is first time I have heard of this, can some one explain?  Thanks.
 :useless:
Don
that is on ym block also.......
nivvy
« Reply #16 on: July 07, 2008 - 02:54:37 PM »
2536430 440 1966-72 RB
3698830 440 1973-78 RB
4006630 440 1978 RB
The block casting numbers for all RB, B, and LA engines are found on the left (driver) side of the block.  In addition, on 1968 and later engines the numbers stamped on the lower rail of the engines right (passenger) side match the last 8 digits of the cars vehicle identification number.
 :2thumbs:
« Last Edit: July 07, 2008 - 02:57:03 PM by StRoKer »
Offline ntstlgl1970
  • T a c o c a t
« Reply #17 on: July 07, 2008 - 02:58:42 PM »
Just some extra info, a "warranty" engine will not have any numbers on the pan rail (have one in my car, it's a 73 440 block)
Offline spes96
« Reply #18 on: July 07, 2008 - 03:19:09 PM »
I've looked all around the distributor but don't see any identifying marks.  Where exactly are they supposed to be?
Thanks
Chris
2009 Challenger R/T
1973 Plymouth 'Cuda 440
2006 4Runner
2005 BMW R1200GS
Offline bb71challenger
« Reply #19 on: July 07, 2008 - 03:20:12 PM »
Thanks
Chris
I will run out to my garage and snap a pic of a bb pad for you so you can see it in relation to the distributor hole.
*Brett*
nivvy
« Reply #20 on: July 07, 2008 - 03:22:09 PM »
Thanks
Chris
the flat pad to the far right of the distributor...
Offline spes96
« Reply #21 on: July 07, 2008 - 03:25:27 PM »
I got it...it was painted over on mine...I had to look at with a glare... Are there other numbers other then F440?
Chris
2009 Challenger R/T
2006 4Runner
2005 BMW R1200GS
Offline spes96
« Reply #22 on: July 07, 2008 - 03:49:01 PM »
Ok after a little cleaning (there must of been 10 coats of paint over the pad)  I have an "F 440 with an upside down A to the right" and a "4 27" below the F 440...
Any inputs?
Thanks
Chris
2009 Challenger R/T
2006 4Runner
2005 BMW R1200GS
« Reply #23 on: July 07, 2008 - 03:51:43 PM »
man I am having a time trying to get a pic of an engine pad in here lol.
*Brett*
« Reply #24 on: July 07, 2008 - 03:54:26 PM »
Any inputs?
Thanks
Chris
If you do not see HP then it is most likely a 350 horse version but it really does not matter if you are going to rebuild it. As it has been stated before, all the stuff that makes an HP an HP goes away with a rebuild and the blocks were the same year to year.
*Brett*
« Reply #25 on: July 07, 2008 - 03:57:28 PM »
F440= 1970 440 installation. Now you can get the casting date off the side of the block. It will be 69 or 70 most likely
Offline spes96
« Reply #26 on: July 07, 2008 - 04:01:02 PM »
Ok, I am straight now...thanks a lot for the education!
Chris
2009 Challenger R/T
2006 4Runner
2005 BMW R1200GS
