Author Topic: Cleaning out the sludge  (Read 572 times)
Offline common 27
« on: July 06, 2008 - 01:59:49 PM »
 I just bought an engine and it hasn't been run for quite a while.Pulling the distributer it has a bunch of dried sluge on it so I pulled the valve covers and it is the same way. Sould I just run it like this and change the oil often or can I pull the intake and pan off and spray some type of cleaner in it and let it run out the bottom? If I did this what would I use that would not harm any thing if a little didn't drain out? It is sitting on a trailer now so it wouldn't be a problem to do .Any one ever did this or any other suggestions?  thanks
1970  Challenger Convertible   1968 Satellite Convertible
Re: Cleaning out the sludge
« Reply #1 on: July 06, 2008 - 02:15:23 PM »
I have idled engine using diesel fuel & 1 qt of oil for a few minutes , it will remove a lot of sludge , make sure you cahnge the filter after as well
Offline common 27
« Reply #2 on: July 06, 2008 - 02:19:13 PM »
 A buddy just told me of a cleaner he uses that he gets at Wal-mart, He says it comes in a qt. can and you pour it in and idle before an oil change,ever here of that stuff and does it work?
« Reply #3 on: July 06, 2008 - 02:46:21 PM »
some of those products work OK as well , I still think diesel is faster
Offline MrMopar440
« Reply #4 on: July 07, 2008 - 03:34:54 AM »
I have to agree with Chryco on this one - diesel works wonders
