Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Intake change 340
« previous
next »
Print
Pages: [
1
Author
Topic: Intake change 340 (Read 490 times)
mikerallye
Jr. Member
Intake change 340
on:
July 07, 2008 - 09:00:15 AM »
With all of the intakes available, can one assume an increase in power by just bolting on a new one? For instance, I am considering putting on a edelbrock rpm intake. Does the carb have to match the intake and should the cam be matched as well. Is it p ossible to lose power by changing the intake alone?
Logged
Changin Gears
Sr. Member
Re: Intake change 340
Reply #1 on:
July 07, 2008 - 09:04:34 AM »
The factory intake is pretty hard to beat on a stock engine. You probably will pick up a few hp, cerntainly won't lose any. There is one thing for sure, you will lose ~20 pounds off the front of you car.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
July 07, 2008 - 11:34:36 AM »
the factory intakes work great , the RPM is an improvemnet in most cases , you need to match the powerband of the cam & intake for best results , a stock cam & a race intake will have powerbands at nowhere near the same RPM & you will not have much effective powerband , the same is true the opposite way , using a race cam & stock intake will not make you happy either
Logged
71chally416
Resident
Reply #3 on:
July 07, 2008 - 12:39:54 PM »
You'll probably pick up a tenth on your ET by just having the heat blocked to the Intake (The RPM has no heat passage) + the weight savings + the better design of the manifold. It's supposed to be 5hp better than the old LD-340 that was the best Intake for street 340's for decades. It's a worthwhile investment IMO.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Intake change 340
