Author Topic: Progess on the Chilly-Challenger!!  (Read 10511 times)
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
Re: Progess on the Chilly-Challenger!!
« Reply #30 on: October 09, 2008 - 09:57:15 PM »
Chally looking good.... On the T/Q be sure the choke coil & pull-off are correct, it's easy to put all that together wrong or not have work correctly due to adjustments. Be sure to re-tighten the 10 screws after a heat cycle, don't forget the 2 in the primary throat.
You know your stuff Bullitt, I ran into both these things! the choke flaps wouldn't close -forgot to tighten screws in promary slot....and choke coil from 2 bbl doesn't fit with 4 bbl, same with kickdown linkages....guess you need to source these from a factory 4bbl intake?
« Reply #31 on: October 09, 2008 - 10:11:42 PM »
if you need a different kickdown most folks like lowkar or bouchillion units
http://www.bouchillonperformance.com/BPEtkdc.asp
What does your choke coil well look like..... '73 units readily avail.
http://www.autozone.com/R,1409207/vehicleId,1406802/initialAction,partProductDetail/store,31/partType,00215/shopping/partProductDetail.htm
« Last Edit: October 09, 2008 - 10:15:16 PM by bullitt99 »
Offline e-tek
    • E-Tek Resto's
« Reply #32 on: October 14, 2008 - 12:01:34 AM »
Got lucky - happened by a freinds mechanic who had an old NewYorker. Robbed it of it's 4bbl kickdown, springs and choke coil - all in nice shape! Got lucky this time. Thanks for the links - I didn't know if the choke would work, but it's the same as the pic in your second link.
Offline e-tek
    • E-Tek Resto's
« Reply #33 on: November 02, 2008 - 07:41:14 PM »
Paint went on and the color sanding's almost done!! I can see some parts actually going on!
Offline e-tek
    • E-Tek Resto's
« Reply #34 on: November 02, 2008 - 07:52:05 PM »
Things are ready to go together and  - OF COURSE - the first thing I run inot is seat covers (PUI from Year One) that are msiing several pull-tabs. These are the pulls that you insert the metal rods that get hog-ringed into the foam bucks. PUI obviosuly forgot some of them on this set...lets how long it takes to get 'em replaced.
Anyways, it was getting late - so I'll wait for the new covers to come and get onto some other stuff...
« Reply #35 on: November 03, 2008 - 01:00:56 AM »
Looking Good  :2thumbs:
 don`t forget to flat black the center hood latch support as well
Offline e-tek
    • E-Tek Resto's
« Reply #36 on: November 03, 2008 - 09:41:37 PM »
Good eye!! I had a heck of an internal struggle over painting the rad support and brackets car coloured, or correctly - black. The "show" cars always have the rad support painted car color and it looks so good, nice and clean...but as you can see I went with the black. I still have that support, plus the other two items that bolt to that to do.
Offline e-tek
    • E-Tek Resto's
« Reply #37 on: November 16, 2008 - 07:42:55 PM »
Here's the rad support blacked out, plus some of the engine bay details soft-installed. As well, I've got a few small pieces done in the engine bay and dash...
Offline Travis72
« Reply #38 on: November 17, 2008 - 01:43:28 AM »
Nice work!!!
Travis
72 Cuda
Offline Street_Challenged73
« Reply #39 on: November 17, 2008 - 05:30:27 AM »
That's coming along very nicely!! :drool: :drool:  That car is going to look killer once it's back together! :cheers:  Nice job with the attention to detail, too. :2thumbs:
Offline e-tek
    • E-Tek Resto's
« Reply #40 on: November 22, 2008 - 08:49:56 PM »
A few more things tackled this weekend! I was repairing the cracks in the dash - in order to put the dash cap on - but as I was repairing I thought it looked pretty good....so I think I'll attemp a full repair on the original to see how it looks. If it looks good, great - if not, I have the cap.
Offline e-tek
    • E-Tek Resto's
« Reply #41 on: November 22, 2008 - 08:51:30 PM »
I also painted the booster (again) using Eastwoods Cadmium-plating paint system (Gold, Red, Green Cadmium paints, plus clear). YOU TELL ME if you think it looks good enough...I'll reserve comment until I hear from some of you!
Offline e-tek
    • E-Tek Resto's
« Reply #42 on: November 22, 2008 - 09:01:04 PM »
And some miscellaneous bits went together or are process now....
Wiring is going back in. Labelling everthing certainly helps!! I'm still not sure about the shiny electrical tape. I might prefer a cloth "hockey" tape....Comments? As well, I'd like it to look as straight and neat as possible, while being stock....any ideas?
The carpet is too wide and doesn't appear long enough. I can see trimming the sides...but should I have to add to the end?!
I really like trying to re-use everything. Refurbishing the rubber plugs for the floor and trunk isn't oo hard.
And a trunk load of bits and pieces....
Thanks for looking!!
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #43 on: November 23, 2008 - 03:14:32 AM »
Looking great!  Keep up the good work!  :2thumbs:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline dutch
« Reply #44 on: November 23, 2008 - 04:12:36 AM »
 :wow:     really starts to look like a car again  :2thumbs:
*** Bart ***
