Author Topic: help with this build  (Read 749 times)
Offline 70ptta
« on: July 07, 2008 - 07:29:22 PM »
Heres what Im starting with.
440 block
440 source 512 stroker kit
edelbrock 84cc heads
edelbrock rpm intake
Holley hp 950 carb
What would be a good cam, headers, 1.5 or 1.6 rockers?  Is 10.5 the max I can go with these heads?  What kind of numbers would this be good for?  Im looking for 500 to the wheels through a 5 speed and id like a nice flat power curve not just big peak numbers.  Give me your  :2cents:  Thanks
« Last Edit: July 07, 2008 - 07:54:15 PM by 70ptta »
nivvy
Re: help with this build
« Reply #1 on: July 07, 2008 - 07:39:08 PM »
well 500 to the wheels I hope you have some bottom end protection... and the heads should have atleast a stage 2 port job and a roller cam...  i dont like the intake choice.... maybe a m1 would be much better for the power range desired  :2cents:
Offline 70ptta
« Reply #2 on: July 07, 2008 - 07:45:45 PM »
Also has to run on 87 octane.  Just kidding 91 and be good on the street.  By that I mean Im not trying to build a daily with this but I dont want a radical race car that cant idle in traffic.  Bay area traffic sucks.
« Last Edit: July 07, 2008 - 07:52:23 PM by 70ptta »
nivvy
« Reply #3 on: July 07, 2008 - 09:52:52 PM »
solid roller cam with 1.6/1.7 rockers.... low duration yet get good lift for power.. and a good cooling system  :2cents:
« Reply #4 on: July 08, 2008 - 02:37:42 AM »
too many variables , it can make great power, 500hp will be easy  , the STreet Dom is another good intake , the RPM surprised me with the power it can make as well , there are excellent grinds from Lunati & Engle , but what RPM powerband , flat tappet or roller cam
 you should be able to get close to 11:1 compression with alum heads again depending on cam etc
