Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Flip Top gas cap
« previous
next »
Print
Pages: [
1
Author
Topic: Flip Top gas cap (Read 3159 times)
Daves74chally
Jr. Member
"Yea.... I need another new pair of tires"
Flip Top gas cap
on:
July 08, 2008 - 11:38:36 AM »
Does anybody know if a flip top gas cap is different from 70-74 on challengers? Iv been searching for one at a good price and i seem to have found one on ebay.
Thanks
Logged
1974 Dodge Challenger 414 stroker, 727 trans, 8 3/4 posi [OO/`````\OO]
Buffalo, NY
MJS73
Sr. Member
Re: Flip Top gas cap
Reply #1 on:
July 08, 2008 - 11:59:27 AM »
It was only offered from the factory '70-'71.
Logged
www.mikes73.com
Don't PM me - send me an e-mail at
mjsavage2001@yahoo.com
72hemi
Resident
MEMBER SINCE JANUARY 2006
Reply #2 on:
July 08, 2008 - 12:11:02 PM »
They fit all years, there is no difference.
Logged
1996 Dodge Viper GTS Coupe
tactransman
Sr. Resident
1973 Challenger- Member here since April 14, 2006
Reply #3 on:
July 08, 2008 - 12:16:43 PM »
Quote from: 72hemi on July 08, 2008 - 12:11:02 PM
Yup, I put one on my '73.
Logged
Terry
-tactransman
Union, Mo.
pink panther
Resident
Reply #4 on:
July 08, 2008 - 12:43:23 PM »
Logged
Scott - Member since 9/18/2005
73Chally
Resident
Reply #5 on:
July 08, 2008 - 02:30:26 PM »
Me too. If you are putting it on after market quarters your might have to trim the 4 mounting tabs on the repro cap, but easily done.
Logged
purplehrtchallenger
Jr. Member
Re: Flip Top gas cap...how about the trim ring?
Reply #6 on:
August 21, 2008 - 01:49:06 PM »
hey guys,
got the flip top gas cap an teh trim ring...well, when i put the trim ring on under the fip top, it is really loose and rattles against the body...is there a gasket or something to secure this?
thanks
PHC
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #7 on:
August 21, 2008 - 02:03:43 PM »
probably not stamped exactly correctly , it should be tight against the body , you may need to make a gasket or tighten the mounting somehow
Logged
RusTy/SE
Sr. Resident
Just havin' fun
Reply #8 on:
August 21, 2008 - 08:03:22 PM »
While I was at this year's Mopar Nationals, one of the vendors had a passenger side NOS full quarter panel. I remembered the issue of flip top fuel cap assembly fit from some previous thread(s) and took a coupe of pics of the gas cap area in case they can be compared to see the difference between (claimed) NOS and aftermarket versions. This way someone could see the extent of any modifications needed ahead of time. Not the best quality but still maybe they can show the diff
Russ
Logged
Russ
2001 Durango 1B4HS
1970 Challenger JS29U
Restoration thread:
http://www.cuda-challenger.com/cc/index.php?topic=27173.0
422STROKER
Sr. Resident
Member Since 6/3/06
Reply #9 on:
August 21, 2008 - 08:48:09 PM »
I think on my repro I adjusted the little tangs on the trim ring to snug it up. It was really loose before I did it.
Tom
Logged
Tom
nivvy
Guest
Reply #10 on:
August 21, 2008 - 09:09:56 PM »
mine fit fine on my 72... I fastened it with allen heads and nylocks so it couldnt be stolen .......
Logged
Scatterbrain
Jr. Member
1973 Challenger
Reply #11 on:
August 21, 2008 - 09:50:00 PM »
mine fit perfectly on my 73
Logged
71chmark
Full Member
Reply #12 on:
August 22, 2008 - 08:13:02 PM »
Had the same problem. I put some gasket material between the mount and the trim ring and it worked fine.
Logged
I may be schizophrenic,
resq302
Sr. Member
Reply #13 on:
August 23, 2008 - 09:53:42 AM »
We recently had the same problem with our chally. The car had repro quarters put on prior to us getting the car in May and dad wanted the flip style gas cap on it as well. He got a repro flip style cap and it would not fit snug but ended up having the trim ring loose. We compared it to a chally next to us at the Mopars @ Englishtown show and found out that the stamping on the repros are not correct. The fuel area stamping on originals are more defined and are a sharp 90* bend where it gets recessed. The repros are a lazy gradual slop inward which is making our twist on gas cap stick up above the rest of the quarter panel. Luckily, I was able to find a patch panel that someone had cut out around the gas fill area for $10 at the show and now dad can have that grafted into the car so it is correct.
As far as which repro quarters are on the car presently, I don't know but the resto is about 2 years old. Hopefully they have corrected the stamping issue since then.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Flip Top gas cap
