Spoke with Ron. He is willing to give us 20% off with as few as 5 buys! Pretty decent deal I think...
MOPAR POWERED EXPRESS WIRING Buy - XP-68 $439.95-20%= $351.96
COMPLETE WIRING SYSTEM
Wiring for one-wire alternator (external alternators add VR-99). This kit will wire points, aftermarket and electronic (factory or dealer supplied) distributors. It also allows for connecting the Chrysler starter relay for use of the factory transmission-mounted neutral safety switch. Our printed and color-coded HIGH TEMPERATURE fire-resistant wiring is supplied for all circuits, including for the lighting needed for most safety inspections: Hi and Lo beams, indicator lights, brake, turn signal, parking and third brake light. The EXPRESS has been improved over previous models to simplify and speed up installation, facilitated by our famous COLOR CODED INSTRUCTIONS. The kit includes a headlight switch, isolated cooling fan relay with wiring and a unique serial number that allows us to give technical support to you and any subsequent owner.
Our newest custom wiring system is built specifically for your vehicle with all the connectors and wiring necessary to drive it, pass inspection, and be able to add accessories as you see fit, now and in the future. We have included the cooling fan relay & wiring. This is due to the fact that more and more customers are using electric fans. Now you can have everything centrally located for a cleaner installation! We've also added a Multi-Connection Battery Junction Block to reduce the number of wires going to the starter for all those add-ons in your custom application.
*Clear Coated, Polished Stainless Steel Finish
*18 Circuits on 16 Fuses
*4 Select-A-Fuses
*Faster Installation with New Style Terminal Block
*Cooling Fan Relay & Wiring Included
*Only the Best Quality Wire and Terminals
*Proper Size Heavy Wire for Each Circuit
*Handles 100 Amp Alternators
*Serial Number
*Includes the Proper Connectors & Terminals
*Clear, Simple, Color Coded Instructions
*Get the satisfaction of wiring with upgraded components
The Express is a direct replacement for all previous Ron Francis kits. It has a very similar bag structure to the past models. All variations of alternator, distributor and steering column are available. Along with the cooling fan wiring and the Multi-Connection Battery Juntion Block, it has 16 fuses, 4 of them select-a-circuit, for complete flexibility in building it your way. The 3-digit part number series harnesses indicate engine manufacturer. Some foreign applications are available.
Dash ignition and floor dimmer switch users update to new reliable switches. Order RON FRANCIS WIRING Part # SW-37.
If you have an externally regulated alternator we recommend ordering the Voltage Regulator (Order RON FRANCIS WIRING Part # VR-88).
